Valve lapping
3rd generation View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 3rd generation Quote  Post ReplyReply Direct Link To This Post Topic: Valve lapping
    Posted: 2 hours 28 minutes ago at 8:25pm
I’m sure this has been long discussed if lapping is needed. I just had hardened seats installed and valves ground. Personally I trust modern machining for a good seal. How many of you still lapped valves with hardened seats?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 29 minutes ago at 9:24pm
always a good idea to get a finish lap.. if nothing else, to CONFIRM it is correct..
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 31 minutes ago at 10:22pm
Can't hurt? When seats and valves are ground/cut correctly it's not needed.
