Unplugged
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Topic: Unplugged
    Posted: 20 Nov 2025 at 5:33am
Have a couple two prong power tool cords that come apart too often. Is there a fix besides tying them together? Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2025 at 6:18am
Some (not all) prongs are a folded over design with a slit between them. Take a flat blade pocket screwdriver and spread the slit apart to your liking.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2025 at 6:36am
Thanks Dr Allis! I'll check it out
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2025 at 7:13am
I hadn’t thought of spreading the prongs like that but I like that better than bending them a bit as I have done.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2025 at 7:55am
We had a Cover that kept the Cords Plugs protected and Connected at the Nuke, was for areas hard to access during power operations, believe that Grainger had them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2025 at 8:08am
Normally it is the FEMALE PLUG that has become WEAK inside and the contacts are spread and not GRABBING the male plug... Same happens with wall sockets when they get old.......... If the plug is FALLING OUT, then the female end needs replaced.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2025 at 3:32pm
Could be the female connection I guess, but I mostly have trouble with my two prong power tool cords. Thanks everyone
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2025 at 4:12pm
cut the 2 prongers  off, install 3 prongers ! Yes, teh ground is NOT connected but it gives 'strength' to keep them connected.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2025 at 4:21pm
Yeah Jay. I've seen adapters so you can use a 3 prong in a 2 prong outlet. Wonder if they make any the other way? Thanks
