Allis WC engine
Ttague39B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ttague39B Quote  Post ReplyReply Direct Link To This Post Topic: Allis WC engine
    Posted: 18 Nov 2025 at 4:36pm
I recently bought a 1937 allis wc, it has the distillate carb and auxiliary gas tank, so I wanted to check the engine number to see if it was truly a distillate engine, and it started with a "W" like it should, but instead of ending with a "K" or "G" like the book says, it ends with a "HA" and I read on a different forum that it means it was tuned for High-Altitude, and I just wanted to check if this was true, and if there was still a way of proving its a factory distillate engine. Any knowledge on it would be greatly appreciated, Thank you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2025 at 8:46pm
You might try checking the compression ratio ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ttague39B Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2025 at 9:23pm
I was seeing that myself, any ideas on the best way to do that? I've seen and been told not to trust a compression test of hand cranking, my thought was hook the belt pully up to another tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2025 at 11:04pm
belt pully idea might work... I guess my question is WHY ?  What difference does it make now ?
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2025 at 6:05am
Sometimes it is nice just to satisfy curiosity Big smile
Belt pulley will definitely 'gitter dun'!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ttague39B Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2025 at 6:08am
Okay thank you guys! Its just neat seeing that out of 178 thousand tractors, there's individuality. Especially to this dagree.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2025 at 6:12am
Since 1937, the engine has surely been overhauled. The great majority of owners 10 or 20 years later saw the advantages of gasoline fuel and when an engine OH took place, got higher compression pistons. Without looking at my service manual, I'd say gasoline pistons would be 110 psi compression and kerosene 80 psi. Check with throttle in the wide open position.
Edited by DrAllis - 19 Nov 2025 at 6:27am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2025 at 6:25am
If the engines starts readily with the hand crank you can pull a spark plug and screw in the compression tester for a 'running' test. Do ground the plug wire to prevent magneto damage.
