AC 170 |
Gpopm55
Topic: AC 170Posted: 18 Nov 2025 at 3:46pm |
My 170 has MS tsx928 carburetor on it. I can only get it to run full choked. Any suggestions?
8070nc
Joined: 21 Mar 2019 Location: North Carolina Points: 703 |
Posted: 18 Nov 2025 at 6:06pm |
Id say the jets are stopped up. You wil need to take it off and clean it
1984 80780
1957 D14 DES 300 with 25000 engine 616 tractor |
ja ecmn
Posted: 18 Nov 2025 at 7:37pm |
Some years ago I purchased a 175 that had the TSX928 that would run only with choke on. To make a long story short brought the carburetor to mechanic who found a recent carb cleaning resulted in the Venturi being installed upside down. Has run great since. Just a thought. Good luck.
Claus
Joined: 09 Dec 2009 Location: Hebron In Points: 1166 |
Posted: 22 Nov 2025 at 6:19am |
Manifold gaskets dried out, sucking air?
Claus
Posted: 22 Nov 2025 at 7:31am |
I also always put a can of Seafoam in my 170 whenever I gas it up. Helps keep the needle and seat clean. Also recommend an inline filter before the sediment bowl. I added a ball valve shutoff because the one under the tank is not easily accessible. I used a Legend 101-520 1/8” T900.
![]() Edited by Claus - 22 Nov 2025 at 7:57am |
