D series Hydraulics.
joegrgraham View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote joegrgraham Quote  Post ReplyReply Direct Link To This Post Topic: D series Hydraulics.
    Posted: 16 Nov 2010 at 11:11am
Does anyone have a diagram of the hydraulic valve block for the smaller D series tractors? I have an ED40 and need to replace some parts within the valve block, and I was wondering if there is any commonality between other Allis tractors, or if the particular set-up is unique to the ED40?
If it seems like a good idea, do it. It's easier to apologise than to get permission.
Jim Blue View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Blue Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2010 at 2:56pm
There is a diagram in the IT manual for D Series if you have access to one.  I do not have a scanner to post an  image.
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2010 at 6:03pm
I have a D-10. Even they had 3 or 4 different hydraulic systems through the run of D-10's.
Dusty
Post Options Post Options   Thanks (0) Thanks(0)   Quote joegrgraham Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2010 at 11:19am
The tractor is fitted with three point linkage, and the valve diverts the oil to either the arms or the tipping pipe. At sometime, someone has over-tightened the bolt containing the detent and trapped the ball inside, then, when the detent didn't work, they lost their temper and hit the top of the valve with a hammer. This resulted in the valve catching on the protruding bolt which has taken a chunk out of the valve and distorted it!
So, I'd like to find out if the valve and detent are unique to the ED40, or whether they may be the same in some US built tractors.
