Allis C snap ring pto
3rd generation View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 3rd generation Quote  Post ReplyReply Direct Link To This Post Topic: Allis C snap ring pto
    Posted: 5 hours 40 minutes ago at 7:59pm
I’m needing the snap on input shaft to rear pto drive. I found the same snap ring behind the bearing on input shaft as the shaft enters transmission from drive shaft broken creating excessive end play. I used the rear snap ring to assemble transmission but is it ok to use an external snap ring that holds the sliding gear for pto engagement? I can’t source that style ring anywhere.
