Sickle bar mower
JoeyQ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeyQ Quote  Post ReplyReply Direct Link To This Post Topic: Sickle bar mower
    Posted: 16 Nov 2025 at 5:56pm
Hi, new member here. I recently acquired an Allis Chalmers B and part of the package was a sickle bar mower in the weeds. Where do I find the model number info on the machine? What are some of the identifying features that may identify this mower? Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2025 at 6:07pm
the standard sickle mower for a B-C tractor is just called  "The B-C sickle mower".... it has a frame under the tractor and a main shaft to the back and is belt driven by the PTO.. Sickle bar sicks out the side of the tractor and is driven by a wooden arm and CAM on the center driven shaft.. It works in the horizontal position only..
Edited by steve(ill) - 16 Nov 2025 at 6:11pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2025 at 6:13pm
there was a second option that has a couple extra short arms and cam at the head end of the cutter bar... That allowed it to PIVOT up 90 degrees and you could trim a hill side... Very few of them around......... i would assume your looks like to picture above.
I have a PDF manual for the mower.. If you send me your e-mail, i can send you a copy.
This page was generated in 0.108 seconds.
