Allis Chalmers WD45 Wheel Weight ?
Pointer Hollow Farm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pointer Hollow Farm Quote  Post ReplyReply Direct Link To This Post Topic: Allis Chalmers WD45 Wheel Weight ?
    Posted: 16 Nov 2025 at 2:03pm
So.......I made a deal on an AC WD45 w/ a 3 bottom plow and I am pretty excited about it.  The check was sent and then I need to arrange for a shipper to pick it up and deliver it to me in PA.  I bought it off one of the gentleman on here.
Now to my question.  It has a set of rear wheel weights on it and I arranged to buy a couple more sets.  On the WD45, can a set of weights be mounted on the inside of the rear wheel to cut down on overall width or do they have to go on the outside only?
Thanks in advance!
Edited by Pointer Hollow Farm - 16 Nov 2025 at 5:41pm
Dennis J OPKs View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dennis J OPKs Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2025 at 3:12pm
Others may overrule but my answer is no-outside only with 2 on each side.  Don't know actual inches.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pointer Hollow Farm Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2025 at 9:14pm
2 Max? Does it cause issues or was that per AC?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2025 at 9:19pm
If your intentions are to seriously pull a 3 bottom plow with a WD-45 tractor, the first thing required is full fluid in the rear tires. That figures out to be approx 900 lbs between the two rear tires. It was STANDARD equipment from the factory. Four more wheel weights on the rear is another 500 lbs and that would generally be considered enough for any heavy work.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pointer Hollow Farm Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2025 at 10:24pm
Yeah I will be putting rim guard in the back tires when I put new rubber on it.
IBWD MIke View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2025 at 4:27am
Wheel weights on the outside only. I really like the Oxnard weights I have on my WFE 45, 375 lbs./each, no fluid, plows great. NFE 45 has three sets of F&H, wider but they do the job.
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2025 at 6:34am
Depending on how much plowing oyu need to do, jsut fluid would be enough. Fluid with 1 or weights would certainly be enough. Physically you can put more than 2 weights on each side. I have 3 on mine with no fluid. It's just barely enough for plowing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dennis J OPKs Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2025 at 8:08am
Follow-up, it is also necessary to have a working Traction Booster system.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2025 at 8:50am
AMEN on that !!   I can prove that to myself time and time again by just leaving the Lift/Lower lever clear down and I usually don't get very far and raise it up about an 1 1/2" to get the TBoost gauge to wake up and awaaay we go !!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pointer Hollow Farm Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2025 at 10:23am
Awesome information. Thank you!
This page was generated in 0.097 seconds.
