Newbie from CA |
Rickjr
Joined: 14 Nov 2025 Location: Concord, CA Points: 2 |
Topic: Newbie from CAPosted: 15 Nov 2025 at 6:24pm |
Hello everyone, My name is Rick Jr., and I am a new member from California seeking some agricultural advice. I currently operate a 3-bottom International plow that does not have a gauge wheel attached. I am trying to determine if it is impractical or ill-advised to plow without this component, particularly when working in relatively dry, light soil conditions. My main question is: If I set the depth controls on the tractor, can I expect the plowed ground to remain reasonably level and consistent without the aid of a gauge wheel? Thank you in advance for your help and expertise.
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 88759 |
Posted: 15 Nov 2025 at 6:41pm |
tail wheel makes it easier to set the depth... but a lot of 3 bottom plows in use without one.... Depends on the tractor and ground conditions... all you can do is try it and see the results..
Edited by steve(ill) - 15 Nov 2025 at 6:47pm |
