Ford 750 backhoe
Acguywill View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acguywill Quote  Post ReplyReply Direct Link To This Post Topic: Ford 750 backhoe
    Posted: 09 Nov 2025 at 8:04pm
We have an old Ford backhoe with a 3 speed Clark powershift transmission that is having issues. When shifting into forwards it takes a few seconds to engage no matter which gear is selected. Put it into reverse and it works fine. Shift from reverse immediately to forwards it works normally but if I shift from reverse and hit the brakes and then into forward it takes a few seconds to engage again. I disconnected the dump control valve that disengages the transmission when hitting the brakes but that has made no difference. Oil level is good and it doesn't seem as if the transmission is slipping any as it pushes good. Any ideas?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2025 at 6:28am
Seals internally are hardening and failing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acguywill Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2025 at 8:47pm
What's more likely, the forward clutch seals or the shuttle valve? I used it tonight to feed the cows and calves and it seems to be somewhat random. More like something sticking or blocked. I will have to do some research on this thing.
orangeman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2025 at 8:14pm
If you have a parts book for the machine I would check to see if the design of the shuttle includes a screen in the sump.  If so, it would be reasonable to clean the screen out and retest.  ~ Orangeman
