CA Hand Clutch
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Topic: CA Hand Clutch
    Posted: 05 Nov 2025 at 7:44pm
Pulled the hand clutch from the CA today, it is well lubricated Tongue
CA13414 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CA13414 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2025 at 7:53pm
That is indeed well lubricated!!!!
A mess of leaking oil and years of organic material. Our was full of corn shucks and grime was packed in like a bird nest. All the oil and worn down springs and clutch plate = slipping.
At least yours was one unit. Some or our trouble was because the hand clutch was not bolted to the brake unit and loose (all 6 bolts were sheered off). Thus, was the source of noise and failure to disengage and re-engage.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2025 at 7:11am
The surprising thing is that the clutch wasn't slipping and seemed to function correctly in all respects. Granted, we never worked it very hard either; this is the tractor that I purchased earlier this year for cheap and have been tinkering on ever since.
The main clutch is worn out so we have it split and both final drives are off; an unrelated semi-emergency developed with my Son-in-law's truck that requires shop space so the CA is now shoved to the side for the duration.
Chaimers View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chaimers Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2025 at 6:10pm
If you have it tore down that far did you give it any thought about putting the hand clutch on the left side? I feel it should have been over there from factory. JMO
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2025 at 7:05pm
Yup, as a matter of fact, Grandson and I have already made that decision in order to be able to run the hydraulics at the same time as releasing the hand clutch. Not quite sure what we will use to steer with, knees, perhaps? Tongue
rilenz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rilenz Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2025 at 5:27am
I always wanted to move the clutch to the other side. But didn't think it was possible . Is it a real problem or more or less switching axle and clutch parts side to side?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2025 at 5:43am
We have yet to complete this project, but I have read several threads about this, and all indications that I can see since opening up the tractor appear to be 'just' a matter of switching components. "Nuthin' to it but to do it" Wink
I fully intend to post updates as we make progress.
Post Options Post Options   Thanks (0) Thanks(0)   Quote rilenz Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2025 at 5:49am
will definitely be on the lookout for your progress and hopefully attempt the task after the winter plowing I do with my ac ca
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2025 at 12:57pm
I opened up the Lambert clutch today, at a bare minimum it is in need of new clutch linings, re-surfacing the pressure plates would probably be advisable. Also, the brake drum surface is heavily worn.
I am open to suggestions Smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2025 at 1:59pm
Check with Rick Corder. That clutch disc uses the exact same lining as a certain hated color tractor's brake disc. He's not doing clutches any more, but he just may reline that disc for you.
If he won't I could reline your disc.
Edited by PaulB - 18 Nov 2025 at 2:00pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2025 at 6:33am
Thanks Paul, I may need to take you up on that offer, Rick was pretty adamant when announced that he was quitting the clutch business.
Post Options Post Options   Thanks (1) Thanks(1)   Quote rilenz Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2025 at 8:18am
Hey Les according to a fellow on here he used a piece of DOM pipe
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2025 at 8:45am
That would likely be the easiest way to facilitate sleeving.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2026 at 1:02pm
Well, I am somewhat sad to announce that we will NOT be moving the hand clutch to the left side at this time Cry
The reason is economic rather than technical, to wit: In order to move the clutch to the other side requires pulling or pressing the brake drum from the pinion shaft; my brake drum is serviceable and there is no leaking of gear lube from the outboard side.
I don't have a suitable puller for the task, and having it pressed off would mean taking it to a press.
After researching this it also seems that there is a high probability of breaking the brake drum in the process due to the relative brittleness of the drum and the fact that they have been stuck on there for well over half a century.
This is a risk I choose not to take at this time. If the brake drum were in need of replacing I would just cut it out of there and be done with it.
Sorry to have disappointed you.
Ken Mn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken Mn Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2026 at 2:36pm
Les: I have had the hand clutch out of my 1953 CA a few times and did not have to press or pull anything off. There is a key way on the shaft that goes to the final drive and a splined shaft from the differential into the clutch unit. I have always left the shaft in the differential and removed the clutch assembly from it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2026 at 4:54pm
Yup.
Reckon I wasn't clear in my post; it is the other side that would need pressed out in order to swap the hand clutch to the left-hand side.
I have had the hand clutch out, rebuilt it, and now it has been re-installed on the original side. Smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2026 at 11:51pm
I don't know these tractors. I assumed you just swapped axle hsg side to side and clutch went with it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2026 at 8:09am
That would be too easy! Big smile
The CA housings are definitely not ambidextrous because they angle down and backward to increase the overall length of the wheelbase rather than being straight down like the B's and C's, plus the hole where the clutch actuator lever goes in is toward the front (there is one on each side).
While the housings were off I was able to peek inside at the differential gears, they appear to be virtually pristine; I also took the transmission side cover off and those gears are in excellent shape as well. This tractor looks like it has led a relatively easy life.
We originally split this tractor to fix a leaky rear main seal and replace the slipping clutch. I pulled the flywheel yesterday and there is no evidence of a seal of any kind having ever been in there Shocked The groove in the seal retainer is clean and completely empty. I have seen a seal missing a chunk of cork on my Model C but this is a new one for me. It really didn't leak any worse than the one with the chunk of cork missing though.
Edited by Les Kerf - 08 Feb 2026 at 8:12am
wjohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2026 at 10:02am
You lucky dog!! LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote rilenz Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2026 at 7:04pm
Sorry to hear you are not moving your hand clutch. But my next ? is did any CA's come with the lever on the left side and if not was it terribly difficult to move.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2026 at 7:51pm
I have read that some were shipped on the left side but I have no proof.
The only thing that kept me from doing the swap is the fact that I was too chicken to attempt pressing the brake drum off of the left-hand shaft. There is truly no reason this swap cannot be accomplished though as long as you are willing to do the complete disassembly of both sides, then swap them.
The operating handle may need some modification (bending?) as it will point the wrong way.
This page was generated in 0.118 seconds.
