Bolt size for flower pot hubs
Joe(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(OH) Quote  Post ReplyReply Direct Link To This Post Topic: Bolt size for flower pot hubs
    Posted: 05 Nov 2025 at 12:31pm
Anyone know what size bolt to put flower pot dual hubs on?  I plan on installing a set this weekend and was trying to be lazy about determining bolt size.  Thanks!
Life is simpler when you plow around the stump.
Jordan(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2025 at 9:39pm
Couple self tappers oughta do it.
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2025 at 5:47am
Joe, I don't know specifically but a lot of dual hubs use 5/8" bolts/studs. Fine thread most times, 18 pitch I believe. The ones that mount the hub to the center could be 3/4" maybe?
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2025 at 11:13am
It's been a lot of years since I put mine on my D21. Likely 3/4" to mount the hub to the center. There are two different sizes of studs to mount the dual to the hub.
Edited by Calvin Schmidt - 15 Nov 2025 at 9:29am
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2025 at 12:39pm
Guess I will need to take a closer as I plan to move them to another tractor. I did see they are carriage bolts and appear to be 5/8”. As for length, will get back to you on that
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2025 at 6:22pm
Ok, I know it's late to the party but here it is:
On our tractor the flower pots are held on with ¾"×3½" grade 5 carriage bolts
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2026 at 8:40am
Thanks for the information!  I finally got back to working on it and 3/4 by 3 1/2 were perfect.  I had to use a few 3/4 by 4, but they work fine as well!  I appreciate the help.
This page was generated in 0.178 seconds.
