Do these pins look worn? |
Post Reply |
KevinON
Orange Level Joined: 07 Dec 2009 Location: Schomberg, ON Points: 786 |
Posted: 16 Nov 2010 at 6:21am |
Just looking over the variable speed on my M, and was wondering if these pins look worn. Is it rebuildable? Thanksuploads/2039/Gleaner_M_Combine_Photos_Nov10_004.jpg
NEJim
Orange Level Joined: 02 Sep 2010 Location: Eastern NE Points: 226 |
They look pretty worn to me. It's easy to replace them by screwing them out and screwing the new ones in. Use some thread lock on the new ones....
KevinON
Thanks, NEJim! You are confirming what I thought. There doesn't seem to be any noise from them at all, but I thought they were looking worn. Take care.
jiminnd
Orange Level Joined: 16 Sep 2009 Location: Rutland ND Points: 2227 |
Also check the bushings in the sheave, if they get too bad will vibrate and wear the shaft, experince speaking.
Steve M C/IL
Orange Level Joined: 01 Jul 2010 Location: shelbyville IL Points: 691 |
Replace pins and bushings and it will last longer than you.If you are a real "tight wad" you can drive the bushings out and turn them 180 deg to have original new wear surface.These only wear on "load" side.
KevinON
Hey guys, can this all be done with everything still on the combine, or should it be taken apart. I may take it all apart sometime, and replace the big bearing on the cross shaft, just for insurance. It is easier to change now, than in the field in August!
NEJim
Kevin, it's not bad at all to take apart. As long as you are into it, bearing replacement is probably a good idea. Then it's all new and good for several years.
Post Reply | |
