180 Tractor Serial Number Location?
emh1889 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote emh1889 Quote  Post ReplyReply Direct Link To This Post Topic: 180 Tractor Serial Number Location?
    Posted: 02 Nov 2025 at 5:41pm
Where is the serial number tag located on a 180? The engine serial tag is visible and in good shape, but don’t see one for the tractor itself. The tractor was painted once before so I’m wondering if the tag has been lost?
Trying to figure out the build date and track down some history on it
Straanger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Straanger Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2025 at 8:00pm
Tractor data just says “Front of the torque housing”
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2025 at 8:21pm
It’s not a tag. It’s stamped
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2025 at 8:42pm
Look at the edge of the torque housing right behind the engine. On my 220 it's on left side.
KJCHRIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2025 at 11:30pm
left side, on Torque Tube/clutch housing. It's stamped into the casting.
Post Options Post Options   Thanks (0) Thanks(0)   Quote emh1889 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2025 at 3:57am
Thank you guys
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2025 at 8:02am
About 1 inch behind here the left side frame meets the bellhousing. The numbers will be up and down starting at the top with 180-XXXX- D or G.
Post Options Post Options   Thanks (0) Thanks(0)   Quote emh1889 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2025 at 8:11am
Thanks, saw that but wondered if it was just a casting number
