Replacing a cab on a k2
Michiganmilkman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michiganmilkman Quote  Post ReplyReply Direct Link To This Post Topic: Replacing a cab on a k2
    Posted: 01 Nov 2025 at 9:37pm
Hello. I went and looked a k2 combine tonight. The combine itself was in decent shape. The cab on the other hand was a mess. There is rust holes in the roof and around the windows. Question i have is how big of a job would it be to replace the cab? And would any 2 series cab work? Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2025 at 7:05am
I'm going to guess here and say any K-2 cab should be right (obviously) and I imagine any F-2 cab should be too. The M-2/L-2 cabs might be a little different. And I have never changed out a combine cab.
JimWenigOH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimWenigOH Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2025 at 8:59pm
They're not bad at all to change out. I had mine off some years ago when I was going through the machine. Mine didn't have A/C in it at that time which made it easier. I removed all the mounting bolts, pried up each side a little at a time to put some blocking between it and the floor, enough to get forks underneath, and then lifted it off. Have some photos of it somewhere. Take the old one off first then you'll have experience for the good one. I still have a parts machine with the cab on it that you could have. Have had it covered, but I think water had gotten under the tarp and laid on the roof. Would have to look. North central Ohio.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michiganmilkman Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2025 at 2:28pm
Thanks for the replies,
I would be interested in that cab im about a hr north of the state line in michigan. Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimWenigOH Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2025 at 4:12pm
I took a quick look at the roof after my first post, and it will need a wire brushing and paint, but was solid looking. If you intend to get it, I will make a more thorough look. My wife would like you to have it too. I would imagine you intend to install a cab kit while you're at it.
Joe(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2025 at 7:48am
Put an N series cab on it or better yet, a 2 series rotary Gleaner cab. If your going to go through the  work make it worth while!
Life is simpler when you plow around the stump.
