1981 Gleaner F2 Fuel Issue
Tnewsome View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tnewsome Quote  Post ReplyReply Direct Link To This Post Topic: 1981 Gleaner F2 Fuel Issue
    Posted: 29 Oct 2025 at 4:12pm
I know this has probably been discussed, but I’m having no luck finding the solution. I have a new to me Gleaner F2 with the Allis Chalmers 4 Cylinder Turbo Diesel Engine in it. I have fuel all the way to the port where it enters the injection pump, but can’t get anything out of any of the four injector line ports coming back out of the injection pump. This machine has been sitting for the last 8-10 years. Do we think it is the fuel shut off solenoid inside the top of the injection pump? Looking for pointers. I haven’t taken the top off of the injection pump yet to check, just wanted to gauge the audience’s opinion first. Any help or pointers will be greatly appreciated!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2025 at 5:25pm
A functioning electric shut-off can be heard "click" when the key is turned on or 12 volts is applied to the wire. On/Off you should be able to hear something. Might take two people and the cab door needs to be shut.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tnewsome Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2025 at 5:26pm
Can this be heard inside the cab or at the injection pump?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2025 at 5:32pm
At the pump !!
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2025 at 7:17pm
Most likely the metering valve and/or plungers are stuck, sitting in today's diesel fuel is not good on injection pumps. If taking top cover off reveals it's nasty inside, you're better off just taking it off and having it properly torn down, cleaned and rebuilt. If it ends up seizing the head, it gets really expensive to rebuild and buy a head & rotor, and drive shaft and gear as well. I don't think new heads are available anymore, so good used is our only option. I like to keep people from seizing them up to start with. Good luck!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tnewsome Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2025 at 7:19pm
Can any diesel shop rebuild? What is your recommendation Ed?
im4racin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2025 at 8:32pm
Send it to ed
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2025 at 8:41pm
X2 on what imforacing said
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2025 at 8:42pm
Im4racin. Didnt mean to mess up your name
1984 80780
1957 D14
616 tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2025 at 9:12pm
In theory yes. Seems harder to find a good shop these days. Many on this forum have done business with Ed and know him to be above board and top notch in his work. You probably have an "ED" in your neck of the woods but I have no clue how you find him. Good luck and one rebuild is all it will ever need.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tnewsome Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2025 at 10:03pm
Ed, would this be something I could send to you for rebuild? Let me know information on this. Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2025 at 8:23am
Yes, I get pumps shipped to me every week from all over the country. I'd avoid the post office, I prefer ups. As mentioned above, I've done work for a lot of members on this page. I work on all color tractor fuel injection systems, but am an AC guy myself, having a few orange tractors lol! If want to send to me, pm me and we can communicate that way, or can call/text my cell. 815-303-3492. If I don't answer, make sure to leave a message, I am very busy, and also get a lot of junk calls.
This page was generated in 0.258 seconds.
