CA Hydraulic/Transmission Oil
dfwallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Topic: CA Hydraulic/Transmission Oil
    Posted: 29 Oct 2025 at 12:26pm
CA recommended SAE 10W <40f, 20W >40f
I bought hydraulic fluid at NAPA, showed them a picture of the 10W20 product I wanted, paid, but they brought out a 30W product and put it in the car.  I didn't pay attention that they didn't give me what I asked for.  Anyway, the pump works well but sometimes it takes a while longer than desired to prime.  Nobody uses SAE oil ratings for hydraulic fluid any more, and it's not clear what the best ISO grade to use is:
SAE 10 weight viscosity:  45mm**2/s at 40C, 7.0mm**2/s at 100C
SAE 20 weight:  61mm**2/s at 40C, 8.5mm**2/s at 100C
ISO 32 weight:  32mm**2/s at 40C, 5.5mm**2/s at 100C
ISO 46 weight:  46mm**2/s at 40C, 7.0mm**2/s at 100C
ISO 68 weight:  68mm**2/s at 40C, 9.5mm**2/s at 100C
None of the ISO ratings match the original specs.  I don't suppose those were too precise.  I'm inclined to go with ISO46AW.  But that seems to equate more closely to a SAE 10 weight.  Hopefully, the "AW" additives will help make up for any differences.  yes/no?
Why are they rating these at 40C??? that's 104F (and 212F).
1952 CA13092
Les Kerf View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2025 at 1:26pm
Considering the 'relatively' light work your CA will likely see in Texas, I would use the ISO 32. If you intend to cultivate cotton in 95 degree heat for 12 hours at a time then use the ISO 46.
The ISO 32 works perfectly in my somewhat cooler climate here in northern Idaho, ISO 46 is somewhat sluggish.
Dennis J OPKs View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Dennis J OPKs Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2025 at 1:46pm
I have used straight 30w non-detergent in KS, not zero temps and it works fine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2025 at 5:34pm
Why wouldn't one use 821XL/PermaTran/HyTran/HyGard ???  All readily available and correct everything mixed in.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2025 at 5:41pm
At some point, AC added a check valve in the inlet, presumably to improve priming.  1952 doesn't seem to have a check valve/ball.  It's a minor problem, but sometimes it can take 10-15 seconds (or longer if its cold) before it starts to pump, usually on a fresh startup.  May be a combination of wear and oil viscosity.  With thicker oil, it was nearly impossible to get it to prime.
1952 CA13092
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2025 at 5:44pm
That's roughly what it has in it (821Xl compliant).  That's roughly 10W30 and it has trouble priming sometimes.
1952 CA13092
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2025 at 6:05pm
The tractor is in Indiana.  It will have a relatively easy life for the foreseeable future.  It may on occasion do some plowing/discing.  My brother is eyeing it for his garden.   It may be used for some brush hogging if I get the smaller one working, but mostly finish mowing.
1952 CA13092
Post Options Post Options   Thanks (1) Thanks(1)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2025 at 7:51am
The CA system is very very BASIC... ISO 32, 46, or 68 normally works fine.. If YOUR tractor specifically has trouble priming and you know the 46 has an easier time, then that is totally acceptable... HYTRANS type oils are also commonly used, but they can be 30wt on some brands.. some are 20wt and some are 10w30 type viscosity.. You have to watch that if you normally have trouble with 30wt oils..
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2025 at 7:52am
PER GOOGLE---
Here’s a handy chart to help you find the equivalent ISO grade for a given SAE weight:
SAEISO/AW
10W32
15W or 20W46
20W68
30W100
This oil conversion chart is approximate.
Note: ISO grades overlap with SAE weights in some cases. For instance, ISO 46 can replace both SAE 15W and 20W oils depending on the temperature.
Edited by steve(ill) - 30 Oct 2025 at 7:55am
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2025 at 9:45am
i use hydralic transmission oil in  my C , and in all my allis tractors i use the  brands dr. allis listed  or ones with the same qualitys like mobile424
Edited by HudCo - 30 Oct 2025 at 9:48am
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2025 at 10:44am
PER GOOGLE---
SAEISO/AW
10W32
15W or 20W46
20W68
30W100
Yup, I saw that.
1952 CA13092
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2025 at 10:46am
That's what I have in it now and it isn't quite behaving as I'd like.  Once it primes, it's fine.  I know that it has trouble priming with thicker oil.  I just don't want to run something that's too thin.
1952 CA13092
This page was generated in 0.199 seconds.
