D 15 engine oil
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Topic: D 15 engine oil
    Posted: 28 Oct 2025 at 5:33pm
Another dumb question, maybe. When I check the oil with a cold engine it's a touch low. After engine warms up oil level is on the line. Seems it should be the other way around to me. Thanks for any insight
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2025 at 5:42pm
Google...
Yes, oil expands when it gets hot, a phenomenon known as thermal expansion. This is why it's important to check engine oil levels after the engine has been running for a few minutes and then has been allowed to sit for a few minutes to drain back into the oil pan, as checking it when cold can lead to overfilling if it's topped off to the "full" mark
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2025 at 8:45pm
Steve,is what you say in the manual? Never heard of warming a little then setting to check oil. Can't imagine full cold could grow enough hot to matter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2025 at 9:30pm
i dont know about manual.. this is just a GENERIC comments about oil expansion due to heat... It can happen... E J just wanted an explaination of WHY the level changed with temp... I normally check oil level cold and call it good..
Edited by steve(ill) - 28 Oct 2025 at 9:32pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2025 at 4:49am
Thanks Steve I didn't think about oil expansion. Makes sense. Guess if I add a little oil to get the level on the full line it wouldn't hurt anything?
Edited by ACinSC - 29 Oct 2025 at 4:52am
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2025 at 11:08am
Im no engine scientist but ive ran this stuff since i was a boy. Id keep it on the full mark when cold and go about my business. Id rather have it a little too full than too low. I read somewhere that when the 8000s came out they were loosing engines on steep hills in wheat country. AC engineers solution was to run them a gallon over full. Dont know if it is true but seems reasonable
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2025 at 2:48pm
It was after fwa arrived on the 8000's. They could climb too steep or go down hill too steep and ran out of oil. A gallon over still isn't near the crank.
