WD45 factory power screen
Farrell(Utah) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Farrell(Utah) Quote  Post ReplyReply Direct Link To This Post Topic: WD45 factory power screen
    Posted: 27 Oct 2025 at 10:05pm
.  One of my WD45s with factory power steering is acting like there is not enough flow to the pump.  Tte steering wheel can only be turned really slow and growls.  A look at the parts manual did not show a screen that may be dirty.  Any ideas on the cause of my problem?
A(1937), 2 G, 2 WD45 diesels, 6 WD45 gas, UC, 2 WD, D17 gas, WF, Farmall 400, D12, Kubota B3030
Post Options Post Options   Thanks (0) Thanks(0)   Quote Farrell(Utah) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2025 at 6:46pm
The problem is solved.  The supply line from the tank to power steering pump was too flimsy and was crimping nearly shutting off the flow of oil to the pump.
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2025 at 7:09pm
Excellent! Thanks for letting us know
