ANOTHER WD/WD45 hydraulic pump question |
AC WD45
Joined: 28 Sep 2009 Location: Mid Michigan Points: 2078 |
Topic: ANOTHER WD/WD45 hydraulic pump questionPosted: 27 Oct 2025 at 7:49pm |
I was given a pump off what I believe was a WD. Looking at the two they appear to be the same pump. This pump is known good, and I believe mine on my WD45 is starting to get weak/noisy. However I have read somewhere that WD lacks the traction booster system. I assume this would be alleviated by swapping the valve body on the top of the pump. Am I correct in my assumption? Or is there something totally different abojt the two that I am missing?
Edited by AC WD45 - 27 Oct 2025 at 7:50pm |
German Shepherd dad
1957 Allis Chalmers WD45 #WD234847 1951 Allis Chalmers WD #WD88193 |
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 4065 |
Posted: 27 Oct 2025 at 7:58pm |
does it have a control rod going down to the hitch on the wd pump?
DrAllis
A true model "WD" tractor doesn't have the Traction Booster GAUGE. In order for operators to better utilize the TBoost system, the WD45's all had a pressure gauge so you could see what was going on.
AC WD45
Posted: 27 Oct 2025 at 7:59pm |
i suppose that will be a spring project before I put the loader back on.
German Shepherd dad
DrAllis
Posted: 27 Oct 2025 at 8:07pm |
Pumps interchange, yes.
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8973 |
Posted: 28 Oct 2025 at 8:19am |
They made a different TB cam lever for the 45's. Different profile? I forget what dad said the deal was. Interchangeable but not the same.
