Truck dilemma |
Ranse
Joined: 11 Mar 2016 Location: Tennessee Points: 782 |
Topic: Truck dilemmaPosted: 26 Oct 2025 at 12:33pm |
I recently purchased a 2011 ford super duty truck. It has a 6.7 diesel with 192k miles. I bought this truck for a farm truck not an everyday driver. It looked nice and seemed to run excellent, I thought it would meet my needs. After getting it I spent $960 having a gooseneck hitch installed. I also spent around $800 fixing minor issues I found. But I found one major issue, an upper oil pan leak. This was a big job requiring the transmission to be dropped, to much for me. I found a guy to fix it for $2500. He found a few other issues so it ended up costing about $4000. He also found another problem he did not fix. Metal shavings in the fuel filters. He says the entire fuel system needs replacing. If not, there will be catastrophic engine failure. He explained to me that fords have a poorly designed fuel injection pump that wears out and contaminates the fuel system. A common problem with fords. So I’m at a crossroads with this truck. I’ve already got more in it than it’s worth. I could try to sell it as is and lose thousands I’ve invested and have no truck. Or I can spend more and fix it. It’s probably going to take close to $10,000 to replace the fuel system. Naturally I wish I never bought this truck but I can’t do anything about that now.
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5276 |
Posted: 26 Oct 2025 at 2:34pm |
I met a Ford dealer yesterday at a tractor pull that was telling me all about how he specializes in only Ford diesel trucks. He had 2 of the HARLY DAVIDSON (HoundDawg) edition specials on a trailer that were only used as pull trucks. And he was pulling the trailer that hauled both with a Newest and latest KING RANCH 4 door. So my guess is that there is plenty of money to be made in the repair business of Ford diesels. Of course I don't know of any Ford diesel lover that their truck doesn't spend more time at the shop than on the road.
If I was in your shoes with what you've described, I'd unbolt the hitch and remove anything of value and that truck would somehow catch fire out back somewhere and then a call to the insurance agent would be made. Just sounds like owning a boat: a hole in the water to throw money into. The other option would be to pull the motor for the boat anchor that it is and replace it with a Cummins. The make adapters to put the Cummins into Fords and Chevys, but I've never known anyone to put a PowerJoke or Duracrap into a Dodge. My ideal truck would be a Chey/GMC Cummins powered with the Allison 10 speed auto.
Edited by PaulB - 26 Oct 2025 at 2:35pm |
Ranse
Posted: 26 Oct 2025 at 4:04pm |
I’ve heard about the Cummins swap but I don’t know of anyone who has ever done it. I’m sure it’s not cheap either. I’m going to ask around and see if it might be worth it. In that case I would just drive the truck as is until the engine went down and then do the swap.
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42269 |
Posted: 26 Oct 2025 at 4:13pm |
https://www.google.com/search?q=Injection+pump+failure+in+pickups+-+type+of+pump+and+resulting+damage&rlz=1C1CHWA_enUS627US627&oq=Injection+pump+failure+in+pickups+-+type+of+pump+and+resulting+damage+&gs_lcrp=EgZjaHJvbWUyBggAEEUYOdIBCjU5Mzg1ajBqMTWoAgiwAgE&sourceid=chrome&ie=UTF-8
Diesel pickup injection pumps can fail catastrophically, and the specific failure type and resulting damage vary based on the pump design. The most common types of high-pressure injection pumps in modern diesel pickups are the Bosch CP4, the Bosch VP44, and the Bosch CP3.
< jsuid="TaUOI_b" ="0" -amic="true" -icl-uuid="020cf8fa-f296-45d7-a801-c97f4624368a" aria-label="View related s" ="rBl3me" js="click:&TaUOI_a|S9kKve;mouseenter:&TaUOI_a|sbHm2b;mouseleave:&TaUOI_a|Tx5Rb" -wiz-attrbind="=TaUOI_a_C5gNJc;=TaUOI_a_UpSNec;" -ved="2ahUKEwjj19-d48KQAxWOAHkGHbr-BH4Qye0OegQIARAB" style="margin: 0px 6px 0px 0px; : none 0% 0% / auto repeat scroll padding- border- rgb229, 237, 255; border-width: initial; border-style: none; border-color: initial; border-radius: 10px; height: 20px; padding: 0px; width: 28px; : relative; outline: 0px; cursor: pointer;">http://www.w3.org/2000/svg" viewBox="0 0 24 24"> Bosch CP4< jsuid="TaUOI_h" ="0" -amic="true" -icl-uuid="3a48a20d-2d0f-4e4d-879b-3b4d42712f41" aria-label="View related s" ="rBl3me" js="click:&TaUOI_g|S9kKve;mouseenter:&TaUOI_g|sbHm2b;mouseleave:&TaUOI_g|Tx5Rb" -wiz-attrbind="=TaUOI_g_C5gNJc;=TaUOI_g_UpSNec;" -ved="2ahUKEwjj19-d48KQAxWOAHkGHbr-BH4Qye0OegQIAhAA" -processed="true" style="margin: 0px 6px 0px 0px; : none 0% 0% / auto repeat scroll padding- border- rgb229, 237, 255; border-width: initial; border-style: none; border-color: initial; border-radius: 10px; height: 20px; padding: 0px; width: 28px; : relative; outline: 0px; cursor: pointer;">http://www.w3.org/2000/svg" viewBox="0 0 24 24"> This high-pressure common rail pump is used in many Ford, GM, and Ram diesel engines from the 2011 model year onward. < jsuid="TaUOI_k" ="0" -amic="true" -icl-uuid="ac5dbb14-ab08-4b22-900a-7d640aa9db81" aria-label="View related s" ="rBl3me" js="click:&TaUOI_j|S9kKve;mouseenter:&TaUOI_j|sbHm2b;mouseleave:&TaUOI_j|Tx5Rb" -wiz-attrbind="=TaUOI_j_C5gNJc;=TaUOI_j_UpSNec;" -ved="2ahUKEwjj19-d48KQAxWOAHkGHbr-BH4Qye0OegQIAxAB" -processed="true" style="margin: 0px 6px 0px 0px; : none 0% 0% / auto repeat scroll padding- border- rgb229, 237, 255; border-width: initial; border-style: none; border-color: initial; border-radius: 10px; height: 20px; padding: 0px; width: 28px; : relative; outline: 0px; cursor: pointer;">http://www.w3.org/2000/svg" viewBox="0 0 24 24">
Bosch VP44< jsuid="TaUOI_1d" ="0" -amic="true" -icl-uuid="626c47bc-00d4-42be-a131-e50782f2df30" aria-label="View related s" ="rBl3me" js="click:&TaUOI_1c|S9kKve;mouseenter:&TaUOI_1c|sbHm2b;mouseleave:&TaUOI_1c|Tx5Rb" -wiz-attrbind="=TaUOI_1c_C5gNJc;=TaUOI_1c_UpSNec;" -ved="2ahUKEwjj19-d48KQAxWOAHkGHbr-BH4Qye0OegQIBRAA" -processed="true" style="margin: 0px 6px 0px 0px; : none 0% 0% / auto repeat scroll padding- border- rgb229, 237, 255; border-width: initial; border-style: none; border-color: initial; border-radius: 10px; height: 20px; padding: 0px; width: 28px; : relative; outline: 0px; cursor: pointer;">http://www.w3.org/2000/svg" viewBox="0 0 24 24">
Bosch CP3< jsuid="TaUOI_37" ="0" -amic="true" -icl-uuid="6d7c5a3c-ba0a-4c53-94a4-a0abd44865bd" aria-label="View related s" ="rBl3me" js="click:&TaUOI_36|S9kKve;mouseenter:&TaUOI_36|sbHm2b;mouseleave:&TaUOI_36|Tx5Rb" -wiz-attrbind="=TaUOI_36_C5gNJc;=TaUOI_36_UpSNec;" -ved="2ahUKEwjj19-d48KQAxWOAHkGHbr-BH4Qye0OegQICRAA" style="margin: 0px 6px 0px 0px; : none 0% 0% / auto repeat scroll padding- border- rgb229, 237, 255; border-width: initial; border-style: none; border-color: initial; border-radius: 10px; height: 20px; padding: 0px; width: 28px; : relative; outline: 0px; cursor: pointer;">http://www.w3.org/2000/svg" viewBox="0 0 24 24"> This high-pressure pump is known for its durability and was used on many GM Duramax and some Cummins diesel engines, notably prior to the adoption of the CP4. < jsuid="TaUOI_3a" ="0" -amic="true" -icl-uuid="b41d4bfb-80f2-41dc-b449-c5be95f27777" aria-label="View related s" ="rBl3me" js="click:&TaUOI_39|S9kKve;mouseenter:&TaUOI_39|sbHm2b;mouseleave:&TaUOI_39|Tx5Rb" -wiz-attrbind="=TaUOI_39_C5gNJc;=TaUOI_39_UpSNec;" -ved="2ahUKEwjj19-d48KQAxWOAHkGHbr-BH4Qye0OegQIChAB" style="margin: 0px 6px 0px 0px; : none 0% 0% / auto repeat scroll padding- border- rgb229, 237, 255; border-width: initial; border-style: none; border-color: initial; border-radius: 10px; height: 20px; padding: 0px; width: 28px; : relative; outline: 0px; cursor: pointer;">http://www.w3.org/2000/svg" viewBox="0 0 24 24">
Common symptoms of any injection pump failure< jsuid="TaUOI_48" ="0" -amic="true" -icl-uuid="6879f1ef-c33d-43e0-9879-968912352b43" aria-label="View related s" ="rBl3me" js="click:&TaUOI_47|S9kKve;mouseenter:&TaUOI_47|sbHm2b;mouseleave:&TaUOI_47|Tx5Rb" -wiz-attrbind="=TaUOI_47_C5gNJc;=TaUOI_47_UpSNec;" -ved="2ahUKEwjj19-d48KQAxWOAHkGHbr-BH4Qye0OegQIDBAA" style="margin: 0px 6px 0px 0px; : none 0% 0% / auto repeat scroll padding- border- rgb229, 237, 255; border-width: initial; border-style: none; border-color: initial; border-radius: 10px; height: 20px; padding: 0px; width: 28px; : relative; outline: 0px; cursor: pointer;">http://www.w3.org/2000/svg" viewBox="0 0 24 24"> Regardless of the pump type, a failing injection pump typically causes a range of performance issues that serve as early warning signs:< jsuid="TaUOI_4b" ="0" -amic="true" -icl-uuid="499fd311-85c5-4fcb-b0ca-73776135d9a1" aria-label="View related s" ="rBl3me" js="click:&TaUOI_4a|S9kKve;mouseenter:&TaUOI_4a|sbHm2b;mouseleave:&TaUOI_4a|Tx5Rb" -wiz-attrbind="=TaUOI_4a_C5gNJc;=TaUOI_4a_UpSNec;" -ved="2ahUKEwjj19-d48KQAxWOAHkGHbr-BH4Qye0OegQIDRAB" style="margin: 0px 6px 0px 0px; : none 0% 0% / auto repeat scroll padding- border- rgb229, 237, 255; border-width: initial; border-style: none; border-color: initial; border-radius: 10px; height: 20px; padding: 0px; width: 28px; : relative; outline: 0px; cursor: pointer;">http://www.w3.org/2000/svg" viewBox="0 0 24 24">
Coke-in-MN
Posted: 26 Oct 2025 at 4:18pm |
Seems the New and Improved injection pumps have a great failure rate and when they do they contaminate the full system with impending disaster from tank to pump, lines , injectors and finally bank account .
But remember they meet the government environmental outcome of preventing air pollution - dead trucks pose no problems Truck engine or brand of body - SAME PROBLEM WITH PUMPS across all . Even the filter used is of no use once pump starts it's demise of wear . Edited by Coke-in-MN - 26 Oct 2025 at 4:21pm |
PaulB
Posted: 26 Oct 2025 at 5:30pm |
I'm sure the Cummins swap will not cost what the Ford fix will be and you'll still have a PowerJoke.
Just get a Cummins that was before the 98.5 year in a Dodge or a full mechanical industrial or medium duty truck truck engine. Anything that is computer controlled will end up problems in the long run. If you are really serious, I have a 5.9 VE rotary pump engine I'd consider selling.
Ranse
Posted: 26 Oct 2025 at 6:11pm |
I do have the CP4 fuel injector pump on my truck. I’ve been told by countless people that they are junk and ford should be sued over them. It would have been nice to had this information before I bought the truck. I can’t understand why ford super duty’s are so popular. I see them everywhere
Hubert (Ga)engine7
Joined: 12 Sep 2009 Location: Jackson Cnty,GA Points: 6610 |
Posted: 26 Oct 2025 at 7:09pm |
Ford’s marketing program is one reason for the popularity. And they dodge the lawsuits because the pumps fail after the warranty expires. A lot of people buy the trucks for a status symbol and trade/sell them before they hit 100k miles. Since this is a known defect I feel that Ford should be forced to cover the repair costs.
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 90812 |
Posted: 29 Oct 2025 at 7:49am |
The CP4 is particularly susceptible to failure due to the insufficient lubricity of American ultra-low sulfur diesel fuel.....
THANK YOU GOVT RULES AND REGULATIONS... Sue them !!
AC7060IL
Joined: 19 Aug 2012 Location: central IL Points: 3670 |
Posted: 29 Oct 2025 at 11:34am |
Ranse, sorry to hear of your trucks issues. Thats very frustrating. Ford should have done better…. Definitely not living up to their advertised slogan, “Built Ford Tough..”
So my question about a 2011 F250 / F350 is; Does it have good enough bones for its 6.7 to be rebuilt or for a Cummins swap?? My reply would be no. The 2011 has numerous other issues besides its 6.7. You or others might think otherwise? And that’d be understandable because a new 2025 F250 MSRP begins at $53k towards of $80k…..? Depends, but you may want to “punt” on this 2011? If so, could try for the 1999-03’ F250 & start there? Or older yet, for mostly mechanical type reliable farm truck. I did a 97’ p-pump 5.9 Cummins swap into my 2000 F350 7.3 6 speed @ 275k miles. I acquired good used 170k engine from wrecked D2500($2300), Fummins adapter, engine mounts($2400), Dodge flywheel & starter ($1000), & hired independent mechanic to swap engines & etc($4200). Mechanic did an electric fans for radiator setup. It did ok empty but not pulling a trailer. So I fabricated (DIY) the radiator/intercooler/AC condenser forward 2 3/8” to allow for engine fan clearance. Problem solved. These prices were from 2014 @ $10k to do the swap. End result, I Love the truck!! Mileage now at 333K. Mechanic also installed a jac-brake after turbo that coins with its 6 speed manual. Very nice setup.19-22mpg empty, 13-14mpg with empty flat gooseneck, 9-10 mpg 275 bu gooseneck grain trailer. PM me for more detail. Edited by AC7060IL - 29 Oct 2025 at 12:57pm |
Ranse
Posted: 29 Oct 2025 at 4:16pm |
Thanks for sharing your Cummins swap story AC7060IL. I’ve asked a few people about it but no one who knows much about it. Looks like you spent close to 10 grand on a 14 year old truck. I understand, you probably figured it was cheaper than replacing it. That’s kind of where I’m at too. Is it cheaper to go ahead and pay for the extra repairs than to replace the truck? The money I’ve already spent I figure is lost either way.
steve(ill)
Posted: 29 Oct 2025 at 7:02pm |
Ranse... what all do you get for $10k "system" ......is there any down side to "run till failure" and then do the FUEL system, or does it destroy the ENGINE itself.. ?
Edited by steve(ill) - 29 Oct 2025 at 7:04pm |
AC7060IL
Posted: 29 Oct 2025 at 7:42pm |
Ranse, Check out this video of Dave @ Dave's Auto Center talking about the 6.7 powerstroke. He has other 6.7 videos too. Maybe just browse them. |
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 35678 |
Posted: 30 Oct 2025 at 2:00am |
Have two friends that did the swaps, both stated even as has proven a Great set up, the costs exceeded the value.
Had a boss in 1978, had a 1971 Ford F350 SRW Crew Cab as plain jane as they come, defined Industrial Truck we all called the Green Dragon. He worked and lived outside Sparta IL, took the 300 6cyl out, adapted thru friends of his that worked the Coal Mines around there, a 3/71 Detroit Diesel with a OD Unit so could make speed as only ran half the 300 rpm. Toured the US camping and sightseeing in it with his gal Friend of close to twenty five years(She was married to a different man). 18-22mpg, SCREAMED LOUD even as had muffler at Highway speeds but he loved the old truck. He had run it for almost 35 years when he finally had to eliminate it due to rust away.
Ranse
Posted: 30 Oct 2025 at 10:05am |
Michael V (NM)
Thanks(1)
Posted: 30 Oct 2025 at 11:24am |
Hearing this makes me glad I went with the 7.3 gasser in my new one. Yea,, I know they have had problems too,, but hopefully not as expensive as the diesel, and it will pull whatever I got to tie on the back of it,,,if it's to big for it to pull,,,, prolly needs to go behind the Ole 359 Pete anyways 😉
Hope ya find a solution that's works for ya |
Ranse
Posted: 30 Oct 2025 at 2:24pm |
