D15 Diesel - a couple of things.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Topic: D15 Diesel - a couple of things.
    Posted: 26 Oct 2025 at 9:20am
Brought the newest acquisition into the shop for some winter time TLC.  First of all, I removed the inspection cover under the clutch housing and found what looks to be part of a spring.  Pretty small - Maybe 1/2" diameter.  I am assuming it's probably from the clutch.  Can anyone give some insight?
Secondly, my radiator is missing most of these "nuts" that secure the grille shell to it.  Are these available and does anyone have some?
Many thanks for any feedback!
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2025 at 9:39am
Kimball midwest has rivet nuts to fix that but you will have to also get the tool to expand them
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2025 at 11:11am
Any nut and bolt place can get you a rivnut kit. Buy the install tool and the correct size of thread insert. Fairly easy to use. Very handy to have. You will find many places you can use it. Smile
Edited by Ed (Ont) - 26 Oct 2025 at 5:48pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2025 at 12:40pm
Clutch damper spring end.
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2025 at 6:38pm
Google Spaenar in Kitchener for any fastener.
