HD5G Thermostat
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Topic: HD5G Thermostat
    Posted: 22 Oct 2025 at 8:47am
The Detroit Diesel 2-71 in my Son-in-law's HD5G trackloader doesn't appear to have a thermostat ; I suspected this, but since I installed a new temperature gauge and SIL worked it hard enough that it should have been thoroughly warmed up, the gauge barely moves off the peg. It is nice to know that the cooling system isn't plugged up, but now we would like to get it to warm up properly.
What temperature rating would be best for this machine? We plan to do some digging and loading pit-run gravel as weather permits through the winter; the actual process will be to warm up the machine, load two small dump trucks, shut down and haul the gravel ~1/4 mile away, spread the gravel with another machine, come back, re-start the loader, repeat, etc.
Are there any "Gotcha's" that I should be aware of  before opening the system?
Thanks in advance Smile
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2025 at 11:56am
Since nobody else will stick their neck out. I remember my HD5 running at 160 degrees, so guessing mine has 160 degree thermostat. But that's not from the book, or a real DD expert.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2025 at 1:40pm
Thank you Ray Smile
I did some google searching and came up with a range of 160-180 so I told SIL to get a 180 if available and no less than 160.
Looking at the service manual it appears to be pretty straightforward to R&R the thermostat, the hardest part will probably be removing the hood for access. Unless the t-stat cover bolts twist off Angry
Eric B View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2025 at 3:57pm
These 2-cycle Detroits have so much air flowing through that winter operation requires a good work out to reach thermostat temperature. For the work cycle you described, please let us know if you ever get up to normal temp. range?
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2025 at 8:20pm
Thanks
Will do Smile
This page was generated in 0.056 seconds.
