D 15 road draft tube |
ACinSC
Joined: 16 Dec 2015 Location: South Carolina Points: 3249 |
Topic: D 15 road draft tubePosted: 21 Oct 2025 at 7:07pm |
When I got my D 15 (gas engine) it had one, which I replaced with a regular breather/oil fill. Just wondering if this was O.E. Anyone know? It's a 1961 . Thanks
DrAllis
Posted: 21 Oct 2025 at 9:54pm |
Early D-15's prior to s/n 9001 had an oil fill/breather cap like a D-17 did with no road draft tube. Effective with s/n 9001 (series 2) the valve cover was different and the oil fill cap was a 1/2 turn twist to remove or install and had to have a road draft tube because it sealed up tight. What you have/had, I have no idea.
Edited by DrAllis - 21 Oct 2025 at 11:09pm |
ACinSC
Posted: 22 Oct 2025 at 4:46am |
Thanks Dr Allis. My tractor is 4065 I think? I just came across the draft tube in the shop and thought I'd ask about it
DrAllis
Posted: 22 Oct 2025 at 6:21am |
If you have the correct valve cover (by s/n) there isn't any place to even connect a blow-by tube.
ACinSC
Posted: 22 Oct 2025 at 6:34am |
It came out of the top where the oil fill/breather goes. Thanks
DrAllis
Posted: 22 Oct 2025 at 7:41am |
Sounds homemade to me. A hose that connects to where the breather/fill cap goes sounds like something I would have done to keep oil from splattering on spark plug wires.
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 90618 |
Posted: 22 Oct 2025 at 7:42am |
if you have an old engine with excessive blowby... it was not uncommon to put a draft tube on to keep the oily mess shooting toward the ground and keep it off the engine block and valve cover..
ACinSC
Posted: 22 Oct 2025 at 8:03am |
Sounds about right. Thanks Dr Allis and Steve
