R62 fire unexplained>
Leon B MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Topic: R62 fire unexplained>
    Posted: 18 Oct 2025 at 7:34pm
Raining here today so getting a break to catch up and take a breath. Last Saturday, I had a wedding to go to so my son was cutting beans without any one around. I trust him more than any 25 year old I know, he is very mechanically inclined. He cut around the field, turned around to head back and smelled smoke in the tail wind. He found a 3 foot fire right at the driver side rwa drive motor (where all the chaff rests). Had an extinguisher mounted a foot from the rear entry ladder, he put it out. Burned the covering off the rwa hyd lines under shoe above rear axle. But nothing else looked hurt. We thought maybe the rwa motor or solenoid got to hot or sparked. Next morning we found burn spots a couple of feet in diameter in the area he cut for a long ways. So we decided to leave rwa off. But had no idea how it started, that's a sick feeling. That was Saturday at 5pm we cut beans all day Sunday and Monday until 3pm. He was unloading in the cart that I was in when he came out of the combine in a big hurry. Said he smelled it again. Engine off at this point. He started looking in the area of the rwa, hoses, solenoid, so on. I opened the engine compartment and found puffs of smoke coming from the inside of the C channel of the rear engine main frame directly on the floor. The driver side is capped and have no access. one 1/2 hole under bell housing, smoking. The right side has partial access but smoke was coming out from under the c channel the length of the oil pan from a very small opening. Got some water and compressor to dowse the best we could but very little access. As we were blowing the channel out we noticed smoke coming from the ground next to left rear wheel. An ember had gotten blown out of the c channel, fell to the ground and started burning. Now we know where it came from but not what started it. We cleaned and blew water the best we could. Cut beans Tuesday, Wednesday, then switched to corn Thursday and Friday with no hint of smoke.
So my question, how do you prevent something like this, how did it start? I spend an hour or more, every morning blowing off machine, engine, radiator, filters, clutches, idlers. He can run the machine hard and the engine temp stays in the green. The radiator is clean, hyd oil not hot. Thought maybe filling channel with foam but that is also flammable.
Any thoughts?
Leon B MO
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2025 at 9:02pm
Does your combine’s header use full poly skid plates?
Is your combine’s windshield constantly dirty?
If so, check out this video about static electricity onboard combine.
https://m.youtube.com/watch?v=J1sd5RL5jOA&pp=ygUiQ29tYmluZSBoYXJ2ZXN0IHN0YXRpYyBlbGVjdHJpY2l0eQ%3D%3D
Edited by AC7060IL - 18 Oct 2025 at 9:06pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2025 at 4:18pm
We do have Polly under the sickle and we clean the windshield every day. But I don't ever remember touching the machine and getting a static shock. That is an interesting video though.
Leon B
cjarosz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cjarosz Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2025 at 4:56pm
My r50 was smoldering twice this fall I figured it was chaff coming out of processor the first time but next night same thing. Extremely dusty since beans died and not all the leaves were shed and dust coming from behind. Next day hung a chain from rear axle and not another minute’s problem I know dust on mine collects on the floor between processor and motor thought it was touching the exhaust and coming down but probably more from bouncing but chain seems to have worked btw head does have poly on it, first head with it I’ve had
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2025 at 9:49am
Have a friend with a red combine. Has had several smoldering fires this year combining beans. Static electricity is a big problem when it's dry. He is dragging three chains now.
cwhit View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cwhit Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2025 at 8:22pm
Had something similar happen late year. Left side of machine , smoldering material on rear axle. Check main drive belt ( the big one ) make sure it’s tight. Also the hyd. belt and idler. All this right above the rear axle. If they bounce any there, can cause issues. Just look up there and see if they have been rubbing on the belt guides. Engine fan blows that hot stuff to the left side and then down. Also check electric main clutch. If it slips a little , will throw sparks. Can check easy at night. Would show up more in tuff cutting conditions but maybe not so much this year. Drove me nuts last year.. Be patient, you’ll find it. Good luck.
Post Options Post Options   Thanks (0) Thanks(0)   Quote cwhit Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2025 at 8:24pm
PS.   We also drag a chain now. Mounts to the head . When down, drags. When up doesn’t.
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2025 at 8:48pm
I have for a number of years drug a chain on the bean head. I will start dragging one off of the rear axle for the corn head. I don’t want to take a chance of getting that hung up around the cutting knives underneath.
