7040 power directer
waltw View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote waltw Quote  Post ReplyReply Direct Link To This Post Topic: 7040 power directer
    Posted: 18 Oct 2025 at 10:09am
    When first started it will not move in low.
      In first gear low range with high held down it will pull along but it takes a few minutes to for high to actually lock in, once it will fully ingage in high I can shift
To higher gears and it will and work in high but still want move in low.
      After 15 minutes or so it will start
Working in low . Will work normal the rest of day. I can apply brakes and load it down in low and high, clutches dont slip.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2025 at 4:53pm
Where exactly are you checking the oil for the transmission ??
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2025 at 7:43pm
The transmission oil pressure light can be used to diagnose power director leakage, if it's working.
Post Options Post Options   Thanks (0) Thanks(0)   Quote waltw Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2025 at 4:24pm
Well with it not working right I check it every time I use it try keep it close to or on full on dip stick under seat coming up through floor deck.
No indicator light does not work.
I rigged up a gauge into plug on top of valve.
Shows 170 psi when warmed up.
195 to 205 is normal according to tech manual I have.
Also noticed when it starts working in high before low works that low button is spongy after low starts working low button feels normal
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2025 at 4:57pm
Your gauge should be where you can see it. I think you are low on oil and the gauge would show that. Slide the seat clear back and look at both sides of the dipstick when checking. I'd probably add 2 gallons and see what happens.
Post Options Post Options   Thanks (0) Thanks(0)   Quote waltw Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2025 at 8:31pm
Ok I’ll do that.
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2025 at 8:34pm
When's the last time the suction screen was cleaned down low ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote waltw Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2025 at 9:39pm
Five or six years ago pulled cover off and cleaned was not clogged put fresh oil in new filter between left frame rail and engine.
I haven’t used it a lot in the last five years maybe 50 hr/yr. Probably done 120 hr over last five weeks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote waltw Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2025 at 9:17am
Put couple of gallons in didn’t help. It goes 1.25” above full with dip stick pushed all the way in. Put another gallon in still the same.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2025 at 10:40am
Watch the pressure gauge and see what's going on. While 170 psi isn't what it should be, that is still adequate to make the tractor move and upshift/downshift. It must be less than 100 psi at times when it acts up.
