175 carb needs rebuilt
jbirnsch View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jbirnsch Quote  Post ReplyReply Direct Link To This Post Topic: 175 carb needs rebuilt
    Posted: 16 Oct 2025 at 1:18am
Is there a carb kit worth bringing home anymore? Needs the full kit. Steiner? Do I just go to AGCO?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2025 at 5:54am
AGCO I don't believe will have a "kit" anymore. The 175 carb is kind of an orphan model Marvel-Schebler. AGCO might be the only place to buy a throttle shaft if they even have it. The gasket set parts should be the same as a late D-17 IV. The needle and seat is 70226458 the same as a D-17.  EDIT:  AGCO shows 70226470 for a gasket kit and 70251721 for a repair kit. Whether they have them anymore, I have no idea.
Edited by DrAllis - 16 Oct 2025 at 6:29am
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2025 at 7:50am
If the Doc’s suggestion doesn’t pan out, I have been getting kits from Mikes Carburetor. If you have the carb number you will likely find it on their website.
I got a kit for my Allis FT20-25 and IHC grain truck which has the Holley governed four barrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2025 at 7:58am
Both numbers Dr gave are still available from agco
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2025 at 8:18am
But, neither one have a throttle shaft in them. 70251709 is the throttle shaft.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jbirnsch Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2025 at 12:19pm
Thanks for the PNs. I’ll get on order.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2025 at 5:34pm
If the throttle bore is worn, a new throttle shaft isn't gonna do ya any good. It's the bore that wears out, not so much the throttle shaft itself.  Depending on how much play is in the throttle shaft, I'll either sleeve the bore or if there isn't a whole lotta' play sometimes an oversize seal will tighten things up. It just greatly depends on how worn things are.  HTH
Steve@B&B
This page was generated in 0.079 seconds.
