185 Coolant drain question
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Topic: 185 Coolant drain question
    Posted: 15 Oct 2025 at 3:22pm
Does taking the lower radiator hose off drain the radiator and the block or does the block have another place to also drain it?
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2025 at 3:33pm
It will drain the rad, but not the block.  Block drain is on the right side of the block between the starter and fuel filter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2025 at 10:17pm
I looked but didn't see any where to drain fluid ,there is a freeze plug there. kinda higher up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2025 at 10:38pm
Block drain is directly behind the fuel filter/fuel hand primer. A second block drain plug is directly behind the injection pump.
This page was generated in 0.087 seconds.
