HD11 Main clutch (dry type) |
bottleworks
Topic: HD11 Main clutch (dry type)Posted: 13 Oct 2025 at 5:24pm |
Hello! I've been getting an HD11 back running again after sitting for 10+ years. The main clutch between the engine and transmission will not disengage. When the machine was parked there, it worked correctly. I've loosened the toothed wheel A LOT (counter clockwise). It's to the point that I'm afraid it will unscrew completely. I just want to make sure I'm trying the right things. I've attached a photo. Thus far, I can't get it to break free and slip at all. I'm afraid I'll be pulling the bellhousing. Does anyone have the procedures on how to adjust this clutch? ![]() |
gemdozer
Posted: 14 Oct 2025 at 8:19am |
You could screw the adjusting ring and lock it and greace the shifting sleeve and pull back your 2 stering cluch lever and started the motor with the transmission angaged it should help
bottleworks
Posted: 14 Oct 2025 at 8:26am |
I've done that. At this point, the clutch lever requires virtually no pressure to move it from disengaged to engaged. It's not slipped one bit. I can put it in gear and start the engine and move the machine around. I'm going to try driving it for sometime in my driveway to see if it breaks free. I don't have the blade on it right now, so I can't try to dig into the ground.
gemdozer
Posted: 14 Oct 2025 at 1:33pm |
If you had a big rock or big tree and knock slowly
wjohn
Posted: 14 Oct 2025 at 9:20pm |
In lieu of putting the blade back on... does it have a drawbar on it you could anchor to something really, really sturdy? Not something you'd risk pulling over onto yourself, obviously, for safety reasons... But for breaking the clutch back loose you will probably need something solid to give some resistance and get the clutch to slip free.
bottleworks
Posted: 16 Oct 2025 at 11:32am |
Well, I pulled the clutch apart. It ended up being the right thing to do. The pilot bearing was in the process of failing. I'm trying to get it removed. The loan-a-tool version of a pilot bearing puller isn't up to the task of pulling it. I've got a hopefully better one coming Friday morning. The clutch is still stuck to the pressure plate, which is helpful for now, as it's one less thing to be in the way. There are clear signs of pooling water in the clutch. ![]() |
bottleworks
Posted: 16 Oct 2025 at 11:33am |
And the failed bearing... ![]() |
Les Kerf
Posted: 16 Oct 2025 at 12:47pm |
Yikes!
