AC Running Gears
orange knight View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orange knight Quote  Post ReplyReply Direct Link To This Post Topic: AC Running Gears
    Posted: 12 Oct 2025 at 4:33pm
Ive got 2 AC 7 ton running gears. Both are straight but need the spindles lubed up. Tires do hold air. Have a couple different tongues available for them. Asking $550 each or $900 for both. Can deliver to lathrope, Mo. 952-290-1063
952-290-1063
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2025 at 6:52pm
1st (top) pictured gear is probably an AC 701? If so, it’s ID plates Cat# should read 2013920. The 701s have the newer 1965+ triangle AC decal that is visible on its front frames upper left side. If original paint, 701 should be stenciled on one of the frames side supports(not on front, so must be on rear?).
2nd (bottom) pictured gear is pre-1965 because it’s rear decal mimics a WD45’s “Allis-Chalmers” type decal & has no diamond AC decals. If original paint, it’s model # (700,605,601) should be stenciled on one of its frames side supports.
It could be any of the following; 601, 605, or 700 as they all have 6 bolt wheels. Their ID plates Cat# may read as follows.
601 cat# 2013505,
605 cat# 2013776,
700 cat# 2013847.
Edited by AC7060IL - 15 Oct 2025 at 6:54pm
