I-70 Improvement project
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Topic: I-70 Improvement project
    Posted: 10 Oct 2025 at 2:03am
State of MO, from KC to STL is being revamped, Our sections are Columbia MO to Kingdom City and Wentzville MO to Warrenton for now, after which will be Warrenton to Danville(Loutre River) and Kingdom City to Mineola Hill (the Loutre River opposing bank).
So we started this little soiree' with two Concrete suppliers Just For this highway work, one in Millersburg and one at Foristell, where the latter is just getting to speed, is also KCi and ESS as to Overpass and Bridge reconstruction going on.  The problem I just recognized is the volumes.  The customers will need to be pouring 2000 Yards of Batch EACH at night EVERY Night they pour.  4000 Yards of Concrete Per Night, we cannot supply Sand, NO ONE can Supply Sand at that rate to which the regular usage rates of 200-500yds per day for all non-associated Concrete plants surrounding these sites will not be stopped either.  Is NOT Enough Sand being harvested from the MO River available positions to feed this.  Not Every region of the River has a functional Sand storage region to draw from, ask a Dredge Operator, are Mud Holes, Sand and then Gravel holes, they get drawn down and the river grudgingly reloads those, it does not make sand deposits everywhere nor overnight.
Then The REAL Problem, we are hauling the recovered sand WET, REALLY Wet, as in not having more than one to three days drain/dry down time on the bank, my trailer will be dripping as get to the yard this morning from Sand loaded yesterday at 3:30pm, UNSUSTAINABLE when air temps drop into the Thirties, that point being just a few WEEKS Away.  Will NOT release and Unload from the hauling bed, will Stick and be Stuck, takes time and back breaking labor to Shave the beds once Frozen.  This will not be any better for dredge crews attempting to send that sand to the Bank Piles by raft and conveyors.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2025 at 2:34am
Will put it inti easier math.
1 yard Concrete takes approx 1400 lbs dry sand, 14 cu ft at 100lbs/cu ft.
That will for all the base values of Concrete used per day equate to 7000 tons per day and divide that by a truckload at 24-25 tons is 28 truck loads less that water included. So closer to 32-35 truckloads. Can only achieve Five loads in a 12 hour period so seven dedicated trucks per day. Just for Highway and Overpass work. Can only bank a permit value of sand per quarter, IIRC was 70,000 ton. Ten days supply.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2025 at 6:54am
Engineers and DOT management should have taken this into consideration before planning the schedule for this project. IMHO This will lead to quality deficiencies and safety violations.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2025 at 6:57am
The last years before I retired, I transported cement from the mills to the concrete batch plants for many road jobs around here. These plants would operate 24/7 when the weather permitted. Two major jobs were US 48 across WV and US 219 south of the Pa Pike. Often then were 10-12 tankers unloading any any one time. It helps that there are many cement plants in this area of Md, Pa,VA & WV.
 Also there are many sand pits and many concrete recyclers the reclaimed sand can be had from.
  Back in my O/O days I hauled sand and stone. Those plastic liners where just becoming available. I've seen many times in colder weather those with liners and a barn door just dump out nearly a block of frozen sand. For me it was never that bad as I started my day with a load of stone and sand was always the return and was never on the trailer for much over an hour.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2025 at 6:37pm
Always wondered about that Dave, they have the equipment to do that - but the materials cant keep up!! Been thru those work zones a few times - still a race track and unreal how people drive
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2025 at 6:06am
Sadly, a Competitor Company for River Sand is now looking to Supply as they have purchased far greater Harvesting Rights Permits over the last several decades.  Capital Sand a division of Capital Quarries have the ability to supply five times the sand as keep that amount in stockpile, They also have eight supply centers, have their own contracts with gateway Dredge that also owns several Permits for Sand Harvesting besides their own dredges, can undertake operations at over eight times the values of our local company.  Suspect this will be a beat down when goes down.  Pricing is not that different where the hauling can be accomplished by far greater numbers in private haulage.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2025 at 7:17am
Theres always others that want a slice of pie,, alot of trucking involved and keeping a pay check!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2025 at 7:41am
Foristell end contractor is busier trying to keep up with barriers destruction, still has crews on adding lanes but being distracted otherwise so yesterday ended up hauling a Little to Foristell, a LOT to Millersburg where the Sand Plant is NOT able to keep up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2025 at 5:51pm
Will admit as to Getting TOO Old to keep up the pace I have been.  Get fatigued about mid morning making the drive E on I-70, almost to a drowsy state.  getting up as Body tells me to is not working well with four to almost six hours rack time, too many hurts decide to start throbbing SAME Time.  Do NOT want to end up wrecking at this stage.
Had planned of giving three week notice last Friday but the Company had to release one accident prone individual and I held off, will be dropping that goose egg on my Boss Tomorrow, 10/13.
Arthritis is really mad EVERY Day as awaken, gets worse until can rest at home of a weekend, but then also have Own projects to attend where those are slipping time wise.  Is just time to shut it down, need to be retired.  Doc thought saw a Rheumatoid marker in blood work, a ?T1D? Marker, second draw showed nothing so may be trying to establish, maybe not against my Osteo Arthritis and all the previous injuries it settles into.  Wife also wants to randomly travel in Blue Beast and with the Bike inside the Camper more often, cannot do that if set to working or if crippled up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2025 at 6:39pm
Another big truck crash  out there today , with a fatallity,,, very sad,,
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2025 at 12:54pm
Got worse with contractors, pushing to get more done before winter slows them to a crawl.  DOUBLED Materials needs from 2000t/day to 4000, No Way is that gonna fly.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2025 at 2:20am
That last comment must have hit home with Ma Nature!  Rains turned on, road base at both ends of this here swamped, unable to meet compaction requirements.  Kuesel Co is staged for when rains stop at Wentzville end to Lime Inject for correct compaction rate of the garbage clay base soils from there to Warrenton.  May be a LONG Wait as supposed to go from dripping wet to hard freeze temps in next two weeks.  Suspect the big shove just seen was for naught, Winter is Upon Us.
JW in MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JW in MO Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2025 at 9:45am
They moved Westbound traffic over on the new concrete between Grain Valley and Blue Springs, ought to make for good traction this winter, sure is a rough ride.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2025 at 12:41pm
Have to take wife to St Peters for Specialized Liver Ultrasound soon, should be able to tell what a month and over a half has changed where I was once hauling.
