another restoration question |
Kevin210
Topic: another restoration questionPosted: 06 Oct 2025 at 9:36pm |
I'll try to keep this as short as possible.
Got the injector pump and lines back from shop and they went ahead and painted the pump with their version of allis orange and I have been using majic paint.I also had new lines made and they are of course plain steel. What would be the best or easiest way to paint them,before or after installation.I don't really to paint them on the tractor due to all the over spray and as you all know you can't paint the pump on the back side after it's on.I know,you'll never see the back side,(but) I don't really want to do it like that. Can a roosa master pump and lines be powder coated. Thanks. Kevin. |
AC720Man
Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5400 |
Posted: 07 Oct 2025 at 2:16pm |
I painted my entire 190 after I had the pump and lines off of it for a rebuild. Once reinstalled that’s when I painted it. You don’t want paint on the threads or take a chance of paint entering the pump. Trust me, after 3 coats of paint on the entire tractor there will be paint in behind the pump. Nothing worse than taking new paint off as you install the pump if you don’t do it that way.
Edited by AC720Man - 07 Oct 2025 at 2:17pm |
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7600 |
Posted: 07 Oct 2025 at 3:53pm |
I paint the lines off the tractor to get coverage all around, then reinstall and touch up where needed.
55allis
Joined: 30 Jun 2020 Location: Griswold Iowa Points: 1268 |
Posted: 08 Oct 2025 at 9:12am |
I paint my lines with an aluminum paint, first I’ll tape off the end to prevent paint in the threads.
I put a couple layers of clear coat on the bare pump. |
