6080 brakes
sllimec47 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sllimec47 Quote  Post ReplyReply Direct Link To This Post Topic: 6080 brakes
    Posted: 06 Oct 2025 at 6:55pm
Hey there every one. My 6080 started using brake oil. It looses enough to set the light off in a day, Does anyone have a suggestion as to where it's leaking?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2025 at 9:22pm
Piston seals leaking inside each axle housing.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2025 at 9:39am
yeah as Doc states,,, the issue is one thinks one can stand on the left or right brake and see which one is leaking - the issue is this most of the time seals off the leak and it only leaks under very slight pressure which leads to rebuilding both sides to be sure the issue is fixed
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2025 at 10:32am
With summer work winding down, if I needed to use the tractor, I'd probably start using some 30 wt oil of some kind to slow down the leak. Be assured you'll want to get that stuff out of there when you actually fix the leak, as 30 wt in the winter time wouldn't work well.
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2025 at 12:53pm
Don't use brake fluid in those tractors.
Post Options Post Options   Thanks (0) Thanks(0)   Quote sllimec47 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2025 at 7:06pm
Thanks for the advice. I have ten acres of hay ground I'm working on getting seeded right now so I'll try the 30 weight trick. It sounds like a time involved fix
This page was generated in 0.081 seconds.
