A-6 air conditioner compressor
Michael V (NM) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Topic: A-6 air conditioner compressor
    Posted: 02 Oct 2025 at 4:03pm
I recently put a clutch coil and bearing on the compressor on my 7060, well,, now the clutch hub decides to self distruct,,
Now being somewhat resourceful,, I thought I'd take the clutch hub off the compressor I replaced on my cadillac,, same compressor,,right, oh, but NO!!,, I don't think there are any 2 of A-6 clutches that are the same,grrrr
If that isn't a problem,, the belt groove will be in a different place on the drive hub....luckily, I not having to change that...
Edited by Michael V (NM) - 02 Oct 2025 at 4:06pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2025 at 8:58pm
Well, I ordered a clutch hub off the interweb, looks like it's the right one,, so,, the Ole A-6 gonna live a little bit longer. For nor more than I use tractors any more,, be a long while before I change to a sanden, although, that is preferred, just to many dollars for the few hours a year I put on the tractor nowdays
I only gots about $130 in the A-6 as of now,(clutch coil,bearing,hub) not counting occanasional can of freon or 3
Edited by Michael V (NM) - 08 Oct 2025 at 9:02pm
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2025 at 5:29am
Good morning, Michael. Any time you can fix something for 130 bucks in this day and age, call it a win! Down there where it gets hot, you need to stay cool! Have a good one! Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2025 at 4:29pm
Yra, Darrel,, and my thoughts are,, if it's got it,, it needs to work,, an with my hay fever/allergies,,I kinda need it to work, especially mowing weeds, or cutting hay
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2025 at 8:54am
I spend whatever it takes to have working AC. 2 Gleaners 3 8000's. That's just me.
