Electric G update and questions
phabib View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote phabib Quote  Post ReplyReply Direct Link To This Post Topic: Electric G update and questions
    Posted: 30 Sep 2025 at 10:52am
It's been over a year since I posted here about my plan to electrify a model G for use on a small farm.  I was able to drive it for the first time last Friday.  I work for Zero Motorcycles so I have access to parts at no or low cost, which made things a lot easier.
I went with a 75-7 motor, which can produce way too much power, 68hp and 97ft lb of torque, so I used the motor controller to tune down the max RPM to 1800 instead of 6000 and the acceleration to more closely match an old gas engine.  I may also turn down the rate of torque application to prevent jerking and lighten the load on the old transmission.  That's all powered by a Zero lithium battery.  Because of the available motor torque, I did not need any kind of reduction, the motor goes right to the input shaft via a Paraflex coupling.  There is no clutch and no need to shift gears so you only change gears when stopped.
Still to do, is to connect the clutch pedal and brakes to the motor controller.  I plan to use the clutch as an input to decrease motor power.  For instance, 1/2 way on the clutch and you'll get half of what the throttle is set to, all the way in and the motor stops.  The brakes will be set up so that each brake can work by itself normally, and the motor will stop and go into regen if you use both.  That way you can still use them to turn, but won't fight the motor if you want to stop.
It's been a fun project and everyone on the farm is eager to use it for weeding and after I make a bed shaper for it, forming strawberry beds by machine instead of with shovels and hard work.
Post Options Post Options   Thanks (0) Thanks(0)   Quote phabib Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2025 at 8:28pm
Now for the questions.  The brakes don't seem to be very effective.  No bad grinding noises and they do stop the machine, but I'm not getting a whole lot of braking for my effort.  Is that normal or should I open the thing up and take a look?
If I just want to look at the condition of the brake shoes, can I pull the axle housing with the axle and drum on it and put it back in one piece without removing the axle from the housing?  If I do have to take it apart and replace or turn the drum, the shop manual talks about always using a new clamp ring when putting it back together.  Are those available?
Thanks for any advice.
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2025 at 8:49pm
Be careful with the torque the axles were very to breaking in the G,brakes are fair at best
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2025 at 9:15am
yes you can view the brakes after pulling the axle housings, G’s weren’t known for having the best brakes to begin with. Most likely you’ll find the inner axle seal has leaked on the shoes and/or that the shoes are due for new linings. We’re gonna need pictures of the build when you get a chance!
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2025 at 9:47am
If you pull the axle plan on replacing the inner seals. Pull one axle at a time.
Stan R View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan R Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2025 at 12:31pm
I'm impressed with your project. Post a few pics if possible !
HoughMade View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HoughMade Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2025 at 12:54pm
Great project!  I'm impressed.
What is the footprint and weight of the batteries you plan on using?
1951 B
Post Options Post Options   Thanks (1) Thanks(1)   Quote phabib Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2025 at 11:03am
Thank you for sharing your knowledge about the tractor.  I'll post some photos this weekend if I can figure out how to do it.  I couldn't get it to work when I first tried.
The battery is a 7.2kW battery from a Zero motorcycle.  It is about 10x15x10 inches and weighs about 80 pounds.  It provides about 100Vdc to a Sevcon motor controller.  The motor is a permanent magnet 3 phase AC motor built by Zero.  I got a full battery/wiring harness/charger/controller from a decommissioned bike.  My motor was new, but had a scratch on the paint so couldn't be sold.
TramwayGuy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TramwayGuy Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2025 at 11:32pm
You could also add final drives and brakes from a model B or C and crank up the motor RPM to get speeds back to what a regular G has. The basic transmission and housing is the same as those tractors.
Post Options Post Options   Thanks (1) Thanks(1)   Quote phabib Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2025 at 10:27am
That's good to know about the shared transmission.  I'm capping the motor RPM to what the gas engine did so I should have the same speed.  I can run it up to 6000 RPM but I'm keeping it tuned down to avoid damaging the rest of the machine.  For instance, on the motorcycle the motor is limited to accelerating from 0-6000 in about 0.3 seconds.  On the tractor I limit to 0-1800 in about 2 seconds.
Post Options Post Options   Thanks (1) Thanks(1)   Quote phabib Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2025 at 10:30am
This shows the motor and battery tray.  The motor controller will bolt to the vertical bracket under the battery.  The charger on one side and the vehicle control board on the other.
Post Options Post Options   Thanks (1) Thanks(1)   Quote phabib Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2025 at 10:35am
These are the two spline adapters I made for the Paraflex coupling in the middle.  For the motor spline, I took a motor pulley that drives the cogged belt the bike uses and turned it down for a snug fit into the 1/4" plate.  Both the clutch and pulley are brazed to the plates.  I wasn't sure how the pulley would react to TIG welding so I played it safe and brazed.  There is a lot of surface so I think it's still lightly loaded.
Post Options Post Options   Thanks (1) Thanks(1)   Quote phabib Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2025 at 10:39am
This shows how it all comes together.
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2025 at 6:25pm
I really like this project! Smile It seems to me that this is a perfect application for battery power.
As mentioned above, do be cautious about applying too much torque. The stock engine is rated at 10.33 HP @ 1800 RPM which amounts to somewhere around 30 lbs/feet of torque (if I did the math right). This really isn't very much, and yet they still have been known to break things.
