Plain Old Victor Mouse Traps ?
BuckSkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuckSkin Quote  Post ReplyReply Direct Link To This Post Topic: Plain Old Victor Mouse Traps ?
    Posted: 29 Sep 2025 at 2:17am
Maybe I am missing something and obviously don't know what I am doing.
I have baited countless plain old ordinary Victor Mouse Traps; the kind with the Copper bait holder/trigger thingie.
I have successfully caught thousands of mice with these traps.
However, for the last several years, as delivered, where the cheese goes is a tightly rolled and clinched together toothed business that is useless for attaching any kind of bait that I know of.
I have to firmly hold the Copper thingie while I force the point of a 1/4-inch Wood Chisel in under the rolled crimped toothed thingie and raise/straighten it into a wider-mouthed "U" shape where I press in my cheese.
Once I overhaul them, they work fine = hair-triggered and deadly = so sensitive that my heart-beat will set them off while I am trying to place them.
Is there good reason for the traps to be made as they are ?
Am I the only human alive who doesn't know the trick and am resorting to re-working them so I can use them ?
For me, my way works, whereas the as-delivered is worthless.
thendrix View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote thendrix Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2025 at 5:45am
Congratulations buckskin! You're officially building a better mouse trap! My guess is is like everything else. Just junk. I like peanut butter on a mouse trap. If you just dob it on top they steal it. But if you cram it in the bait holder where they have to "dig" for it, it's bye bye Jerry.
desertjoe View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2025 at 7:02am
 Hey Buckskin,,,,When I DO need some,,I still buy those wooded traps ans Yes,,I do need to " Adjust " the bait part to open it up a tad. Mayhaps,,they know someting that we ain't figured out yet,,,??
Post Options Post Options   Thanks (1) Thanks(1)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2025 at 7:25am
I have to open mine up a bit. And the peanut butter works good. In areas where other animals can’t get at it I put out some mouse candy, green blocks work on mice but I need the yellow blocks for rats.
DanWi View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2025 at 7:37am
The ones we have now have a little yellow plastic paddle with some small holes in it. You just put a dab of peanut butter on. I see on the internet the ones with the roll your suppose to put the cotton from the top of a cotton swab in it and the mice want that for their nest material.
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2025 at 8:05am
Haven’t paid attention to that, have been using peanut butter for decades.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuckSkin Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2025 at 11:33am
Well, that sure is a new one on me; never in a million years would I have thought of using nest material as bait.
I had a bunch of those traps with the yellow plastic paddle and didn't like them as they were not sensitive enough and no way to make them more so that I could figure out.
The ones we had, you actually weren't supposed to need to bait them as that yellow paddle was impregnated with "cheese smell"; --- I always added real bait to them anyway; however, I did have one that I set without any added bait, just to see if there was anything to that "no need to bait" business; that thing stayed set in the shop for years without anything showing any interest in it; and, then, after being there unmolested for ages, it caught a mouse.
I used to swear by peanut butter as the best mouse bait one could use; but, the last few years around here, these mice seem to much prefer cheese.
I can have a trap set with peanut butter for weeks and not get thrown; I can set another right beside it baited with cheese and have one caught within hours.
I will say this, the peanut butter is a lot easier to use.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2025 at 4:07pm
Bacon bits work wonders, sometimes...Wink
Maybe the chinese mice are smaller, so that's why the bait thingie is smaller...
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2025 at 4:45pm
Rats and mice generally run along the base of walls. Put the trap perpendicular to the wall with the trigger end against the wall. The mouse will run over the trap, trigger it and you get a shot at the mouse's entire body. No bait needed. Try it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2025 at 4:57pm
I got overrun with mice here over the winter and up to a few weeks back
Went through over 20 pounds of TOM CAT green mouse blocks
Had a bucket setting on a chair out in shop , had left the cover off the 8 lb pail
3 dead mice in bucket , lot of droppings , and about 3 pounds of blocks gone
By house 8 pounds in 2 weeks , another 2 pounds out by trees where i seen some holes at base .
 I took some 2 pound plastic coffee cans , drilled 2 holes in them with 3/4 hole saw , then ran 2 pole barn spikes up through bottom to place bait chunks on , put some pea gravel in bottom to weigh them down - have to preplace the 4 blocks about every 4 days
  Bought some yellow Just One Bite blocks - some eaten but not as much as small  Tom Cat blocks  . I have 5 of the plastic cans now set around house , going to make up a bunch more to place in and around shop .
 Son had some outfit spray around house and yard for ticks and mosquitoes and they put out to bait stations but never cam back to service them as am sure bait was gone in a week .Just have to figure out what tool opens them
 Have a bait station that holds 12 of the Tom Cat blocks and that gets emptied fast also .
On the Victor traps the liquid mouse bait works well , have got more with that inside house and garage than other bait .
 Have a couple of the see through mouse catching traps 6 x 12 or so galvanized metal box with hole on ends . Problem is live mice - to dispose of them drowning is only way to clear trap without mice running ever where when opened
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2025 at 8:16pm
I feel your pain! The ones I could find had plastic bait tray/trigger. would not hild the cheese. Switched to cheap peanut butter. works like a champ!
I am still confident of this;
Wait for the Lord;
Walker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Walker Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2025 at 9:09pm
They have to compensate for the little buckied incisors too.
jvin248 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jvin248 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2025 at 9:32pm
I just wedge a peanut piece from crunchy peanut butter in that loop.
The victor Tin Cat works too.
Vintage mousetrap channel with a repeater trap too.
https://m.youtube.com/@ShawnWoods-Homestead
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2025 at 6:00am
I use butter for bait, the real stuff not margarine. Seems to work better for me than peanut butter. Have tom cat and various other blocks out in the buildings too. Anything to keep the population as low as possible! What I hate is when the stupid coons start eating the mouse poison. It does kill them, in time. Expensive way to be rid of them though. In the summertime the darn crickets eat any and all mouse bait! They absolutely love the light green tom cat blocks. Catch a mouse in a trap and they start eating them too. Nasty little buggers!
Dirt Farmer View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dirt Farmer Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2025 at 12:21pm
I drill a small hole in a kernel of field corn then using thin wire I wire it to the trigger on the mouse trap. Works great, and get several kills on the trap before having to refill it unless his buddy comes and cleans it off
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2025 at 1:35pm
I have had success using a raisin stuffed into the bait crevice, one raisin will often last to catch several mice.
scott View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote scott Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2025 at 3:17pm
The secretary at the shop I work at brought in a Victor brand electric mousetrap that emptied the building of mice. We caught one a day for two months then nothing for months. In my office I set up a bucket trap and caught a live stray. We hadn't caught anything in the shocker in months so we set the shocker trap in with the mouse in the bucket to test out the batteries and see if it was still working and within minutes we had that mouse. We farted around for years setting traps and wasting time...
This page was generated in 0.219 seconds.
