Need help with hyd cyl seal repair wrench
Eric[IL] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric[IL] Quote  Post ReplyReply Direct Link To This Post Topic: Need help with hyd cyl seal repair wrench
    Posted: 15 Nov 2010 at 11:25am
Got an AC 715D backhoe that has backhoe & loader hydraulic cylinders with seal caps that range from 3.5"-5.75" in diameter.  These seal caps have 3 indentations on them - kinda like a large 3 prong castle nut?  As you can see in the pic, a larger cylinder (5.75"dia. cap) on the boom needs a new seal & I am wondering what people use for a wrench to unscrew these cylinder caps?  Napa dealer said something about a spanner wrench, but I have not found any that look like they would work.  Did AC or other manufacturers make an adjustable head wrench that was applicable for the whole machine?
Chain wrench 3"-6",
large pipe wrench,
what?  Thanks in advance for help.
Big Hunter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Hunter Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2010 at 11:35am
I used a large pipe wrench on one.  Another time I couldn't budge it so I took it to the dealer. I guess if you were good with a torch and grinder you might be able to make a wrench (if you had a long enough...for leverage... and thick enough piece of steel laying around).
When you get that off and pull the rod out there is a nut on the end of the rod that needs to be torqued to around 500 to 600 pounds if it's like the one I had to deal with. (thats from memory...and I lose memory once in awhile).
BobHnwO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobHnwO Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2010 at 12:21pm
Use a flat punch and big hammer,hit counter clockwise to break it loose,then big pipe wrench.
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2010 at 12:29pm
We have a spanner wrench here at work for cylinder gland nuts, its a universal tool.  Depends on how tight the gland nut is on how good it works.  We've had cylinders that were so tight had to weld a heavy iron  to the gland nut, put it in the press and  work it over with a sledge hammer to break loose, also have heated the end of the barrel-that can cause the barrel to swell and not hold the gland nut, so be carefull there.  Ive used the punch-be careful not to damage the nut, use a BIG punch and a BIG hammer, also have use the pipe wrench, use a BIG pipe wrench, sometimes it take a combination of methods to get it to submit!!!  HTH
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobHnwO Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2010 at 12:38pm
On second thought,instead of a punch,use a piece of mild steel,less chance of damaging the gland nut!
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2010 at 12:53pm
Randall Machine and welding uses a 50 ton press with V blocks to hold the cylinder and a 4' pipe wrench to remove tough glands.
Gerald J.
gcalent View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gcalent Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2010 at 1:29pm
I have a large chain wrench that will do 8" pipe, it`s safer that a pipe wrench on large diameter items. It has a 5' handle and is heavy duty enough to add a cheeter handle if needed. Break the nut loose before you remove the cylinder the machine will hold it better than any vise I know of.
Pullin With AC
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobHnwO Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2010 at 1:33pm
When you remove the piston bolt,you will need 3/4 or 1" impact socket with breakover bar and 10' pipe,I bolt the rod to my front bucket with a 1 or 1 1/4 bolt to hold it solid.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric[IL] Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2010 at 2:00pm
Gcalent, is your chain wrench an Armstrong Industrial Tool (AIT) 73235 model?  Napa sells this tool and says it has a 1.5"-8" diameter range.
Post Options Post Options   Thanks (0) Thanks(0)   Quote gcalent Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2010 at 7:06am
I`m not sure of the brand, I think it is a Ridgid, I`ve had it for many years, bought it at an auction, it weighs about 50 pounds. I know it will fit 8" pipe fittings, which are close to 10" outsdie diameter.
Pullin With AC
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2010 at 8:38am
That nut only holds the gland in place and itself is not part of the seal. A large pipe wrench is all I have used on both my 715 and 650 hoe as the cylinders are same OD but the rod is different.
 I had to replace the piston on one cylinder along with the gland , piston was made from aluminum to replace the cast iron one, the gland I got from MINNPAR
Faith isn't a jump in the dark. It is a walk in the light. Faith is not guessing; it is knowing something.
"Challenges are what make life interesting; overcoming them is what makes life meaningful."
