80R Mower on CA
rustyorange45 View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote rustyorange45 Quote  Post ReplyReply Direct Link To This Post Topic: 80R Mower on CA
    Posted: 23 Sep 2025 at 7:39am
I have an 80R mower for my WD45. What mounting brackets do I need to aquire to mount it to my CA? I would imagine they are rare as I have never seen one mounted on a CA. Did they work well with a CA or not? If not that is probably why I have never seen one on a CA.
1953 WD45 WF/Model 90 Loader, Oxnard Rear Blade, 80R Mower, Model 209 Disc, WD Rear Mounted Scoop, Model 184 & 160 Rotary Mowers, 1952 CA NF/L306CA mower, 1953 CA WF/Model 8 Loader.
DennisA (IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2025 at 7:58am
Thanks & God Bless
Dennis
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote rustyorange45 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2025 at 8:10am
Okay, I have watched the video on YouTube.It will obviously work. How hard are the CA mounting brackets to find?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2025 at 8:59am
I used a bracket for the D-14 until I was able to find a pattern and made the correct one.
Thanks & God Bless
Dennis
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2025 at 1:13pm
I used an 80R on a CA for years. The thing with an rear mounted mower is, you'll tend to get a stiff neck.
   The main mount and the correct inner balance spring mounts for the CA/D10,12 may be difficult to find. Get yourself a mower parts book for the 80 series mowers, so you'll know what you're looking for and can recognize them when you see them.
  Of all the mowers I used with a CA, in my opinion the best one ever was the 80S. The 82S is much too heavy for a CA and anything else is a rear mount. except for the #5 which is a pitman mower and if all is good they're OK, although the 80S is far superior.
This page was generated in 0.268 seconds.
