D17 Series 4 spark plug confusion
Rusty Allis View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rusty Allis Quote  Post ReplyReply Direct Link To This Post Topic: D17 Series 4 spark plug confusion
    Posted: 20 Sep 2025 at 9:54pm
Well...
Long story short is I had to pull a plug and noticed that it had Champions (yuck) in it but the plug was a short reach RJ12C plug.
I did find this thread:
D17 Spark Plugs - AllisChalmers Forum
But...it seemed to kind of trail off without any definitive answer.
The threads are LOT longer, so after some digging it looks like I need the long reach plugs.
1) am I correct thinking it really should have the long reach plugs in it and
2) will NGK BP5ES be ok?
and..."while I'm there" can anyone suggest a good set of wires? Delco? Bosch?
Thanks!
KJCHRIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2025 at 11:04pm
we find both short and long reach plugs in them. In theory early D17 will be short 3/8" thread (Autolite 295) and later will be long reach 3/4" thread (Autolite 405). The split is tractor at s/n 75000 / 75001. BUT as D17's are 60+ yrs old you can find some have been pieced back together.
 Always check the heads thread depth to verify which length plug it should have.
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2025 at 9:00am
Champions will work just fine! Lol.. So will the NGK. Or any plug you can find of the correct heat range. Mine ran all its life on used plugs out of our Camaro's and Chevelles. And ran well and still is 60 years later!! Smile
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rusty Allis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2025 at 6:27pm
This does in fact have longer plug threads than the plugs in there now and I'll need to chase the threads.
I didn't measure, but they look about 3/4" long.
I'll order a set of NGK's and see what happens
This page was generated in 0.087 seconds.
