Building kits
jjrosty View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jjrosty Quote  Post ReplyReply Direct Link To This Post Topic: Building kits
    Posted: 17 Sep 2025 at 7:20am
 overmanbuildingssupply.com sells building & house kits out of Arkansas.
These are stud frame buildings(no pole barns)  that are 95% precut , studs,trusses,tin, trim etc.
8, 10 &12’ heights.   Their prices are very competitive.   They will only ship 5 or 6 hours from Pocahontas Ar.
I bought a 36x24 with a 10” lean to.   Excellent company to deal with.
BTW this is a NONPAID recommendation
If you always do, what you always did,
You'll always get, what you always got
scott View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote scott Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2025 at 10:10am
Lots of talk about the need for more housing... someone is going to figure out a better house made cheaper and make a fortune.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2025 at 10:27am
Way back when you could order a full house delivered from SEARS - a mail order house shipped by rail to your local siding .
 Advances now to ship by truck of panelized houses (factory assembled) set in place  by truck mounted crane at homesite .
  The place I have now came in this way (WICK Building Systems out of WI) in 1970.
Mnfarmboy View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mnfarmboy Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2025 at 11:48am
I assembled Wausau Homes for a while. They were a competitor of Wick Homes.
Dave
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2025 at 1:54pm
Dave }  Back when I built the two companies were similar but WICK was a little more finished and higher value with sheetrock where WASAU used paneling
 Later quality of WASAU went up and they offered 2 story units also
Unsure if either is still in business now .
 When I was driving I use to deliver asphalt to plant by WASAU home building site , covered a large area
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2025 at 5:59am
I drive past Wausau Homes every day, they are still there.
I am putting up a house that Cleary Post frame is doing. A large garage attached to the house. Cleary is doing the exterior as a pole barn and I will finish the interior.
http://lonsallischalmers.com
