Model M Mag
LoggerLee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LoggerLee Quote  Post ReplyReply Direct Link To This Post Topic: Model M Mag
    Posted: 14 Nov 2010 at 11:07pm
I went to look at a model M that seems pretty good,it's not froze up or anything,but there's no mag on the thing,I don't want to buy this little critter just to have to spend $500 on a mag,anyone able to tell me what kind of magneto is supposed to go on a M?
Any other tractors use the same kind?
Thanks,
Brian
everett048 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote everett048 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2010 at 2:15am
Depending is the mag base mount or flange mount? if flange mount mag would have been depending on year A fairbanks morse R V 4 B 3 CW ROTATION OR IF REPLACED A FMK43B OR FMO4B3 OR FMZ4B3 OR FMJ4BE ALL  cw rotation if earlier base mount original would have been a eiseman or bendix scintilla hth.
Post Options Post Options   Thanks (0) Thanks(0)   Quote LoggerLee Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2010 at 5:11pm
I didn't look at the serial number,but it's got a base mount with 4 holes,look like they were 5/16 bolts (from memory)
The mount is still there,I imagine that the old fella that owned it took it off and it's in one of the sheds there,but I don't want to buy it and end up sinking way more than it's worth into it,I'd hate for it to go to scrap either though....
That gives me a start Everett,I appreciate all the information I can get,there are lots of HD9s and HD11s up here,but this is the first M I've seen.
Post Options Post Options   Thanks (0) Thanks(0)   Quote everett048 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2010 at 5:38pm
we have 4 of them 1 narrow and 3 wide m,s
Post Options Post Options   Thanks (0) Thanks(0)   Quote LoggerLee Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2010 at 7:56pm
Are Magnetos pretty much standard? get one that fits and time it and it will work kind of thing?
Honestly this will be my first gasoline tractor (other than that little B-10) and I don't know a thing about em',everything else I have is Diesel.
Edited by LoggerLee - 15 Nov 2010 at 7:56pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote everett048 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2010 at 1:45am
Base mounted mags are around just got to look for them Allis,s run with a 30 degree lag on start up so you need to find a mag with a 30 stamped on it, also you will need the little fibre coupler to put between mag and drive on tractor mag is held on with 4 3/8 unc bolts have seen them on ebay from time to time. hth
Post Options Post Options   Thanks (0) Thanks(0)   Quote LoggerLee Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2010 at 12:10pm
Hmmm,this little tractor has nearly ran me out of patience already,and I don't even own it :)
I'm going to buy it anyway,will give me something to do,and it comes with a free Oliver combine!
I'll post up some pictures when I go to pick it up,if I get it before someone else does.
Post Options Post Options   Thanks (0) Thanks(0)   Quote LoggerLee Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2010 at 4:28pm
Here are a couple of quick cell phone pictures I took,glad I got it.
steve aust View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve aust Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2010 at 9:54pm
That looks like a nice little crawler, well done
Post Options Post Options   Thanks (0) Thanks(0)   Quote LoggerLee Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2010 at 10:23pm
Thanks for the kind words Steve,I can't hardly wait to make it go now,sure wish it had a darn mag on it,but it should not be that big of a deal I don't think.
I'll probably have to pull the engine and see what's up in the clutch,seems like it's locked in,push the main forward and it flops back,like it's not even attached to anything down there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote everett048 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2010 at 12:57am
Lee clutch works opposit to what you are thinking lever forward clutch DISENGAGED lever back to seat CLUTCH ENGAGED do not leave lever, forward in DISENGAGED POSITION WHEN RUNNING ALWAYS PULL LEVER IN TO ENGAGED  POSITION (make sure not in gear first) also look through inspection hole on top of bell houseing it is a oval cover held on with two bolts 3/4 wrench needed you should see everything move from there.Clutch lever when pulled back to ENGAGE should snap over and stay back. hth if you need more info post here or pm me
Post Options Post Options   Thanks (0) Thanks(0)   Quote LoggerLee Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2010 at 1:20am
That's how I was pretty sure it worked Everett,it just lays back though.
If you push it forward to the disengaged position it just flops back to the engaged position (to the rear of the tractor)
I'm going to go pull the hydro pump off the back tomorrow and bring it home,I have a crane where it's at right now and the pump has to be a couple hundred pounds.
I'll pull that cover tomorrow and see what's moving or not moving in there.
I've been trained on those style of clutches,my uncle has a D4 that you don't leave in gear disengaged,the lever will start bouncing until it gets enough momentum to move the tractor. (One time will do)
And thanks for making sure I knew,this little crawler is a new one on me,everything you know will help :)
Edited by LoggerLee - 20 Nov 2010 at 1:32am
Post Options Post Options   Thanks (0) Thanks(0)   Quote everett048 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2010 at 1:24am
Lee there should be no resistance and the lever floppy once it snaps out of engagement if you push lever all the way forwards it should engage transmission brake to make shifting gear easierfrom start off.
Post Options Post Options   Thanks (0) Thanks(0)   Quote everett048 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2010 at 1:26am
Yes i know what you mean Lee i was run over by a M 3 or 4 years ago.
Post Options Post Options   Thanks (0) Thanks(0)   Quote LoggerLee Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2010 at 1:35am
Right,most have a little spring in them somewhere though,this one does not snap over,just goes clear back,but I still don't have a mag yet,so I have time to check it all out.
Hope you weren't permanently hurt by getting run over,ouch!
Post Options Post Options   Thanks (0) Thanks(0)   Quote everett048 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2010 at 1:37am
no not to bad several broken ribs all over bruising black and blue for a few weeks
am on pc if you use yahoo?
Post Options Post Options   Thanks (0) Thanks(0)   Quote everett048 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2010 at 1:40am
there is springs lee but they are on pressure plate  6 of them i think clutch operates on two cams wich gives the snap effect is the clutch frozen? to flywheel hence the floppy lever.
Post Options Post Options   Thanks (0) Thanks(0)   Quote LoggerLee Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2010 at 6:29pm
Serial number 1614
Makes it a 1935 right?
Edited by LoggerLee - 20 Nov 2010 at 6:33pm
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2010 at 7:11pm
Yes it does. They are nice little crawlers, hope it steers alright for you when you get it running.
This page was generated in 0.281 seconds.
