185 steering wheel oil leak
Joe Goodwill View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe Goodwill Quote  Post ReplyReply Direct Link To This Post Topic: 185 steering wheel oil leak
    Posted: 13 Sep 2025 at 7:42pm
I vaguely remember fixing this issue 30+ years ago on another 185. Oil started running out under steering wheel yesterday. Today when I moved it into the shop there was no oil leak ( probably ran less than 5 minutes. I seriously doubt that that issue can fix itself!🙏🤞
I believe last time I just replaced a seal in the top end of the steering motor. Is this the usual issue or does the whole motor need O-rings and seals?
Thanks in advance for all information and advice..
Joe
lentsch View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lentsch Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2025 at 10:36pm
My FWA 8010 did that occasionally. Replaced the shaft seal and that took care of it, for now at least.Smile
WD,D15,190XT,7000,8010x2,7060,8070
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2025 at 10:38pm
Same on 8070 and F2 Gleaner. Seal up top seemed to fix them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2025 at 7:59am
Get a steering orbitrol seal kit from your AGCO dealer as per the serial number of your 185. Using a 5/16" 12 point socket, remove the top of the orbitrol. Replace the dust seal, the quad ring and one O ring. Do NOT disassemble any further than that. You would think those quad seals would last longer than 40 years, wouldn't you ??
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe Goodwill Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2025 at 12:32pm
Thanks for the replies. This site as always comes through. I found my parts book. I have the part number for the seal kit. Thank you Dr. The one I did 30 some years ago I believe was the same process you just described.
   Much appreciated
Joe
