Oil level 190 xt
JeffB View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JeffB Quote  Post ReplyReply Direct Link To This Post Topic: Oil level 190 xt
    Posted: 14 Nov 2010 at 10:34pm
Can any one help me out, I dumped all the oil from my 190XT including the two rear diffs, Ive filled all the levels back up but I have nothing in the diffs, I thought this was filled from the gearbox in the cab (right side when in the seat), I overfilled this and drove back and forth a bit but nothing is in the diffs. Any thoughts on this as I dont have a operators manuel.
Amos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amos Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2010 at 11:18pm
You fill the rear end with the filler on the left side under the seat and the transmission with the right side under the seat.  They are two separate compartment/gear boxes.
SLee(IA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SLee(IA) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2010 at 11:37pm
The two final drives where the bull gears are have drain plugs on the side at the bottom and fill/oil level plugs on the side to the rear about half way up. Use 90 weight oil. These are different than the transmission and hydraulic that is filled in the cab.
Steve
Post Options Post Options   Thanks (0) Thanks(0)   Quote JeffB Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2010 at 9:10pm
Thanks Steve, I see the two rear filler plugs now, I kept reading all the oil goes in the two dip stick fillers under the seat, nothing about the rear final drives.
Jeff
Amos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amos Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2010 at 6:13am
Hey Jeff, we both just learned something.  I am on my way to check the level in mine right now as I have never done it in the 20 years the tractor has been here.  Sure hope it is OK.
