D15 oil pressure
Dave (Mid-MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (Mid-MI) Quote  Post ReplyReply Direct Link To This Post Topic: D15 oil pressure
    Posted: 10 Sep 2025 at 8:41pm
My Series I D-15 has good oil pressure on startup but lower pressure once warmed up. When warm, the engine must be run 1/3 to 1/2 throttle to maintain pressure in the normal range on the gauge. I switched from SAE 30 oil to 15W-40 but saw no difference. Is this an indication of worn main or rod bearings? Cam bearings?
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2025 at 6:30am
The quickest, easiest way to help that is to add a quart of Lucas oil conditioner. Obviously this doesn't fix the problem but does help the pressure. Cam bearings are probably the issue.
