49 wd hydraulic pump pressure
G226WD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote G226WD Quote  Post ReplyReply Direct Link To This Post Topic: 49 wd hydraulic pump pressure
    Posted: 10 Sep 2025 at 3:18pm
Hi everyone say ive got a 49 wd the pump has been in a cardboard box for a few years and I put it back on just recently pump says 1800psi then 1500psi then now its 1000psi i replaced the long small spring the one for high pressure  the old one made the pump chatter when i engage it  id like to know about the shims on the top as well i want to get just under 3000psi if i can  need a little help thanks
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2025 at 4:21pm
Get a WD or WD45 service manual. It explains the pump very well. I rebuilt mine about 12 years ago.
You need to pull out all 4 of the check valves on top and make sure the springs are good. I think 2 of mine were wore through and I replaced them all and also reseated the balls into the seat. Once that is done and all your orings are replaced. Then you can see where your pressure is at and start adding shims to the unload valve if needed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote G226WD Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2025 at 5:02pm
can i do this while the pump is on the tractor also where in the pump are the orings you are refering to.
i have some parts and pieces for the pump here havent had it mind in pieces in a while part numbers would help  i do not have a service manual    thank you
Post Options Post Options   Thanks (0) Thanks(0)   Quote G226WD Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2025 at 7:16pm
is this what your talking about?  part no 70224670 ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2025 at 5:55am
To fix everything in the pump you need to remove it. You can check and replace the 4 check valve plungers that go in the top while the pump is on the tractor. Before doing much you should go on ebay and by a service manual. It will be 20 well spent.
I don't remember all the details or part numbers now.
This page was generated in 0.174 seconds.
