D17 series 4 air filter cover
Putnamd17 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Putnamd17 Quote  Post ReplyReply Direct Link To This Post Topic: D17 series 4 air filter cover
    Posted: 04 Sep 2025 at 3:00pm
I went to change the air filter in my d17 and after I removed the screw/bolt the piece covering the air filter fell apart. It seems like a cloth type material not really sure what it is. Anyone know of a place to get a replacement for this.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2025 at 3:39pm
Not available anywhere, but not really a problem.  Any air that comes in still passes through the filter, so the engine is still getting clean air.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Putnamd17 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2025 at 5:04pm
Would it be possible to make a metal cut out for it and use that instead?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2025 at 5:22pm
The idea was the material they made it out of sort of sealed the end of the filter/canister area to force air to enter thru the stack. Cooler and possibly cleaner air that way. You can make it out of what you want but a little flexible would be better function wise. A thin piece of rubber belting would work, and see if it can handle the underhood heat.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Putnamd17 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2025 at 5:30pm
Ok thank you.
Ryan Renko View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan Renko Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2025 at 5:58pm
I bought a replacement from Agco about two years ago. It didn't really look like the original and was made out of a thin rubber material and basically just sealed the end. Ryan
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2025 at 7:28am
Love Allis Chalmers but they really dropped the ball on the air filter designs on bothe the Series 4 D17 and the Series 2 D15 . It's like the engineer was almost done and his boss came along and said hurry up we need this design fast . Couldn't make a sheet metal piece with a wing nut to hold it in place ?
Gatz in NE View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Gatz in NE Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2025 at 4:14pm
It's been many years since restoring my D17 Diesel and ran into the same problem.
Here's what I did to keep the design as close to original as possible.
Made a steel ring that fits over the rubber boot and sticks up a bit so that the cross-bar holds it tight.
The cross-bar has a tightening screw that bears down on the end of the filter.
I no longer have the tractor, and don't recall the exact dimensions.
This page was generated in 0.115 seconds.
