Converting 1XX to snap coupler
MadCow View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MadCow Quote  Post ReplyReply Direct Link To This Post Topic: Converting 1XX to snap coupler
    Posted: 01 Sep 2025 at 9:59pm
I'm in the market for a better tractor. One with over 60hp, cab. Better hydraulics.
I really like the looks and specs on the 180,185,190,190xt.
What's the possibility of finding one with a snap coupler hitch?
What's it take to swap in the arms and bell from say a d17?
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2025 at 5:50am
If you find an early 190, some of them had factory snap coupler hitches. I have a one ninety gas with factory snap coupler, and have seen a few others.
Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2025 at 6:26am
D-17 series 4 snap-coupler parts will fit on 170-175-180-185.    D-19 or 190 parts for the larger frame tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MadCow Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2025 at 8:31am
Could you convert a 200 to sc with the D19 parts?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2025 at 8:43am
The lift arm cylinders pin to the axle in a different place. If the upper (D-19 location) anchors have the holes drilled in them, everything should fit. I just don't remember if they drilled the holes or not because they aren't used on a 200.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MadCow Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2025 at 9:19am
Should have asked before I committed in a 190xt then. But I'm pretty happy anyway!
As always, thanks doc
