WD45
acd17toy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acd17toy Quote  Post ReplyReply Direct Link To This Post Topic: WD45
    Posted: 01 Sep 2025 at 6:43pm
           When pulling the gear shift tower  should the transmission  be in a sertin position?
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2025 at 7:49pm
I would try to have in neutral if possible. But I do not know if that is correct! Never had mine apart.
Dennis(IA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dennis(IA) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2025 at 8:06pm
I had mine off a lone time ago (20 years). I took it off in neutral, but then I had a difficult time to put it back on.  It seems to me that it had to be in reverse to replace it.  Everyone I talk to says it should be in neutral.  I don’t know what my problem was.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dennis(IA) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2025 at 8:13pm
Are you pulling the shifting lever or the whole transmission cover?  My comment refers to the whole cover.
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2025 at 6:53am
I believe 2nd gear is where you want it, been a few years since I had one apart. Mine was jammed in two gears so it came apart where it was. Took several tries before I got the tranny in 2nd and back together.
There are some pretty good shift-tower threads on here if you search. Sugarmaker did one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2025 at 8:33am
What does the service manual say???
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2025 at 9:50am
Mike is correct 2nd gear. Shift collar and tower in position.
Post Options Post Options   Thanks (0) Thanks(0)   Quote acd17toy Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2025 at 6:56pm
  Dennis Ia. removing the complete shifting tower.
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2025 at 7:20pm
Sandy lake implement has a complete description on how to do it on their knowledge section
This page was generated in 0.123 seconds.
