185 3 point lift issue
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Topic: 185 3 point lift issue
    Posted: 31 Aug 2025 at 11:39am
Helping my friend diagnose his 185 lift arm issue. it has blown the seals in both lift cylinders, left side first and now the right side is leaking bad. I haven't been around this tractor in 30 years when I ran it for his grandfather pulling gravity wagons during the harvest season. It hasn't seen much use in the last 20 years since his grandfather passed away.  Anyway, I stopped by to see if I could figure out what was going on. He doesn't use the lift arms anymore and after blowing the seals out of the left side he just unhooked the line to the left cylinder and put a plug on the end of the hose. Not the right decision but he did that to get by until he had time to remove and have the cylinder replaced. Using the tractor to pull the square baler or wagons. A month later the right side cylinder started puking fluid. So I got on the tractor, made sure the lift arm control was in the neutral/no lift position and started the engine. the lift arms began to raise, so I moved it to the float position and they still came up. Once they came all the way up it began puking fluid out of the cylinder seals. It appears to me as if it is stuck in constant lift mode. The control rod is moving the control valve through its stroke and feels normal. He doesn't have a service manual on the 185 so I don't have anything to refer to. I'm thinking maybe something is stuck inside the valve body causing it to be in full lift no matter what position the control rod in which blew the seals out? Seams like I remember someone mentioning placing a screwdriver in the access hole on the back of the control valve(bumper plug)and pushing in on the spring to see if its stuck? Is this correct or what do you suggest to figure this out. This has to be hard on the pump and its hard to tell how long he ran it in this condition. I would have suspected a noticable change in the engine and pump sound as it was dead heading the pump? But he said he had not noticed any change.
Thanks in advance for your help
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2025 at 2:38pm
Better be checking the relief setting. Those aluminum pumps split open when stressed.
Boman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boman Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2025 at 4:04pm
Not to hijack this post but does anyone know the collapsed length of the top link on a 190?
None of my aftermarket ones go short enough, off by about 3 inches
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2025 at 5:34pm
If the position control or traction buster levers are to the back it will do that. Or the traction booster spool or linkage could be stuck
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2025 at 5:37pm
Traction booster not buster. Darn spell check. Im gonna turn it off. It does things behind my back
1984 80780
1957 D14
616 tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2025 at 5:41pm
After rereading your post its more than likely the traction booster spool or linkage stuck. If the position control is adjused right it wont dead head the pump
1984 80780
1957 D14
616 tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2025 at 7:18pm
I will check the traction booster lever, I did not see if that lever was working properly.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2025 at 8:10am
It sure sounds like "stuck" Traction Booster OR Position Control linkage under the hyd console, with the linkage finger holding the hyd spool "in" causing it to raise the hitch all the time. The relief valve for this circuit is set to 2100 PSI and I have never seen a relief valve of this design ever fail to a higher pressure. They always blow an Oring internally, and then they don't make 2100 psi any more.   40 year old lift cylinder seals with 2100 psi against them constantly can make them fail, not from too much pressure (2100) but from constant pressure and old age. I've never understood how an operator doesn't notice when the hitch gets to the top of its travel, that there is now a hissing sound coming from the console area. That is the sound of the relief valve doing its job and a clue that there is something wrong. BOTH rear hyd levers need to be fully forward, but that doesn't mean the linkage underneath isn't stuck anyway.  Remove the short aluminum cap/cover (and spring) at the right rear of the hyd stack and with a large diameter punch and hammer tap the spool fully forward until it hits the snap ring. Replace the cover and spring and leave the hyd levers fully forward and you are fixed until the next time someone pulls those levers back.
Edited by DrAllis - 01 Sep 2025 at 8:11am
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2025 at 8:54am
Don't check the lever.  Check the linkage.  There are 2 or 3 pivot points.  If one of them doesn't move by hand, you will have issues.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2025 at 8:06pm
Thanks for the replies, it will be this coming weekend before I can get back to it. I will let you know what I find out.
