While bush hogging
AveryD12 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AveryD12 Quote  Post ReplyReply Direct Link To This Post Topic: While bush hogging
    Posted: 30 Aug 2025 at 7:10am
Well it’s not actually a Bush Hog brand (it’s a Woods brand) but that’s what most folks call them around here. Most of my property is timber land, plantation pine and few mixed hardwoods. Then you have all the undesirable brush. Anyway, while bush hogging along the property line, power line and trails that cut through the woods I got to thinking about ways to eliminate all the under brush and thought about goats. Anyone on here have experience with goats. How to keep them inside fence? Are predators a problem? Any vaccination requirement? Any parasite problems? Herd separation- male isolated from female? Winter feeding? Just a thought for now. Any advice is much appreciated
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2025 at 7:53am
Put some swine in the area. You have to reinforce the fencing more than likely, and have a water source.
iowallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote iowallis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2025 at 11:24am
How long do you need them? A former coworker had a side business of taking goats to areas with thick underbrush/weeds and the goats would clean it up. There is a franchise called "Goats on the Go" but I don't know if he was part of it. One of the local state parks had a goat company come in and clean up an area.
Pricing was dependent on the size of the area, if fencing was needed, and the availability of water.
One of the downfalls to raising goats in this type of situation I guess they are susceptible to some sort of respiratory disease.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AveryD12 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2025 at 12:32pm
Thanks for the reply. I am just considering goats. Know nothing about them. Don’t know anyone that has them. Just looking for some input to try and make a decision. Just looking for pros and cons.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2025 at 1:10pm
Goats as Sheep have worm issues, wormer has to be given routinely and OFTEN, as well rotated from one type to another every time.  They eat seriously close to grade so pick up near to every worm critter known.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AveryD12 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2025 at 8:13pm
Thanks. Didn’t know about the worm issue. Definitely something to consider and also consider how to give them wormer. Is that something in feed or is like worming cattle-shove it down their throat
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2025 at 5:14am
According to Bill, he uses a syringe looks like a meat juice injector, sprays a load down their throats which ends up around half sprayed Back Out on him. He take, he will NOT EVER have worms!!! Worst incident when first started got a full dose sprayed in his face and mouth, wears a rubber meat cutters apron Elbow length gloves a hat and face shield, still catches some.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AveryD12 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2025 at 6:22am
Thanks. Sounds like bush hogging would be easier!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2025 at 6:27am
Goats have a certain odor, different from cows and pigs . But they do eat a lot of brush and weeds . My Sister and Brother in law had 10 acres north of Peoria . About 15 years ago they brought in a guy with About 200 goats . Most of the property was fenced already. He strung up a temp hot wire to keep them in for about a week. They came and ate everything within reach. Beautiful job but it stunk for quite a while. My brother in law was told to start spraying when the weeds started to come back . He never did and the honey suckle took over in about 5 years. They sold it and not sure what it looks like now.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2025 at 6:56am
Goats will eat anything they can bite off. Sheep are about the dumbest animals on the planet and more trouble than they are worth. All of your concerns are valid though. For temporary weed management the easiest thing to do is stake them out with a sturdy chain and move them as needed. That also allows you to bring them to the barn at night.
thendrix View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote thendrix Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2025 at 9:19am
And make sure you bring them in. If not the coyotes sure do appreciate the free "stake" dinner
Post Options Post Options   Thanks (0) Thanks(0)   Quote AveryD12 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2025 at 1:00pm
Coyotes are one of my biggest concerns. Lots of them around here. Can hear them around dark 30 every day. I have had lots of reservations about venturing in to the goats. Most of what I’ve heard here reinforces my concern. I guess I will just bush hog.
Post Options Post Options   Thanks (0) Thanks(0)   Quote thendrix Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2025 at 1:18pm
I'm in the same boat sorta. My wife wants a few goats and we HEAR a lot of coyotes. Don't see a lot. I guess we'll see how it goes
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2025 at 5:04pm
My Dad kept ~100 head of sheep most of my growing up years, plus my Mom always had a few goats. When you read in the Bible those parables comparing us to sheep, it is NOT a compliment!
In my experience, sheep are better at brush control than goats, and they are somewhat easier to fence in.
They are a full-time job. Don't get sheep or goats unless you are really serious about WANTING them. If you truly want them, then you don't need any advice, just do it Smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote AveryD12 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2025 at 8:14pm
Thanks. Can’t say that I REALLY want them. I would like to have them for the brush control. I found a website where someone has posted lots of videos about caring for sheep and goats. Looks like it would turn into a full time job. Rotating grazing areas, fencing different grazing areas, deworming, separating male from female, having a shelter accessible, feeding in the winter…my bush hog is looking better all the time.
